winscp did not write a logging file
zeus_12345
We have a database which creates application calls in this way:
WinSCP.exe ftp://{UserNameLocal}:{PasswordLocal}@{VPN_ADDRESS} /passive /log="{LOGPATH}{YEAR}_{MONTH}\{DAY}_{HOUR}_{MINUTE}_{SECOND}_{DEVICE_ID}_{WIN_USERNAME}.log"
but winscp did not write a logfile. Since we have to log all remote activities, we would need this feature. With ssh the log is working.
I tested /xmllog and /log. I get only the hint, that automatic actions not run if run as commandline
Re: winscp did not write a logging file
What's is the purpose of the call? Just to start WinSCP for interactive use? Or do you add some more parameters like /command to automate some operation?
zeus_12345
the purpose is to start WinSCP for interactive use, the user should not have to enter a logfile or user/password , ftp/scp and the IP
example
WinSCP.exe ftp://user:password@10.10.10.10 /passive /log="d:\connectionlogs\10.10.10.10_2012_10_02_winscp.log"
because we have to save our logfiles.
You can work around that by replacing ftp:// prefix with command line parameter /RawSettings FSProtocol=5
WinSCP.exe user:password@10.10.10.10 /RawSettings FSProtocol=5
thanks for the workaround with
WinSCP.exe user:password@10.55.35.46 /RawSettings FSProtocol=5 PortNumber=21 /passive /log="logfile"
it works.
