Topic "Having problem using -Filemask switch in Synchronize command"
Msledge
Here is my command. I'm using it in a .bat file.
winscp.com /command "open ""asp1""" "synchronize ""-filemask=*.pdf"" local D:\temp\ l:/gms/" "exit"
I've searched through the forums and can't find anything related to using WINSCP.COM
Any help is greatly appreciated.
What problem?
Msledge
prikryl wrote:
What problem?
The filemask switch doesn't work. Every time I try to use it on the command line I get a message saying the switch isn't valid.
I'm trying to use it with winscp.com. I couldn't successfully use it with winscp.exe either. Do you see anything wrong with my syntax?
Thanks for your response.
You are probably using WinSCP 4.x. Please upgrade.
