Topic "specify PORT no. from command line"
cprasad111
when i transfer a file from windows to unix using winscp.com (command line), it does not ask for port number.
when i try the same stuff in putty, the file transfer does not take place unless the PORT is specified.
How to specify the port in command line and why it's not asking for port number?
Does it use a default port (22), In my case, port no. of unix is 22. Is this the reason its not asking for port no. ?
If unix port was other than 22, would it still not ask the port ?
WinSCP uses the default port number for the protocol you are using. What is 22 for SSH.
If you need to specify different port, see:
http://winscp.net/eng/docs/scriptcommand_open
http://winscp.net/eng/docs/session_url
dan_linder
I have found that if you append the port to the end of the "scp://" URL, it works. Here's an example:
    scp://%username%:%password%@%computername%:%portnum%
Saves the time of writing a custom script.
For what it's worth, I'm using WinSCP 4.3.3 build 1340.
Dan
