Topic "Password with special characters invalid in batch program"
jtmorley
I am running version 4.3.2 (Build 1201). I have other scripts running for a different site with a more normalized password. I'm wondering if a password in this format (not the actual password I'm using, but similar) with all the special characters is causing the problem. I tried a couple variations of putting quotes around it, but it failed also. I can get in thru the gui tool, and from command line. I just can't get it to work from a batch program.
C:\cmd>winscp myUserName:t,!wx1`]+J1H@companyInfo.com:2 /script=getStuff.bat
Searching for host...
Connecting to host...
Authenticating...
Using username "myUserName".
Access denied.
Connection has been unexpectedly closed. Server sent command exit status 0.
Access denied.
Authentication failed.
transfer ascii
No session.
C:\cmd>
Please read documentation:
http://winscp.net/eng/docs/session_url
If that does not help, come back.
jtmorley
I did see a post about encoding, and had already tried it. I did notice I missed one, and tried it again, but I'm still not able to get in. What else should I try?
Turn on loggign both in scripting and GUI and compare the logs to see if you are missing something.
jtmorley
I added the logging, but nothing else really popped up. I started looking into just using Putty's psftp option. I got closer with it, but still had trouble with the password. I then tried a suggestion from Putty. Long story short, by adding an extra % in front of each encoded character fixes the password special character problem. Example %2B becomes %%2B.
If you are running WinSCP from a batch file, then yes. You have not mentioned that.
jtmorley
Yes I did. Please refer to first posting.
Ok, sorry. Anyway, did it help?
jtmorley
Yes it did, thanks.
sam_boyz
Martin,
I have a password like <test12;:&>
I am using batch file.
I am enclosing the session url in double quotes as below:
open "sam:<test12;:&>@myserver" -hostkey=*
I am still getting auhthentication failed error?
You have to URL-encode the semicolon:
Martin, I will not know the special characters in the password beforehand as the utility I am creating can be used by multiple users. I want a generic solution if there is?
A generic solution is to URL-encode all non-alpha numeric characters in the password.
If your utility in .NET-based, you can use Uri.EscapeDataString method.
https://msdn.microsoft.com/en-us/library/system.uri.escapedatastring.aspx
