Topic "Encrypt password in script file."
mart
I will like make automation with winscp scripting but i'dont like show password in the script.
What is the best way to encrypt password directly in the scrypt...?
open scp://mart:PASSWORD ENCRYPTED@server -hostkey="ssh-rsa 2048 ..."
Regard,
mart
Teh best way is to encrypt the script using Windows file-level encryption.
dbkcis
Is it possible to hide the script within, and access it directly from, an SSIS package?
David
You can specify the commands directly on command-line using /command parameter instead of using separate script file.
http://winscp.net/eng/docs/commandline#scripting
dbkcis
That was just what I was looking for. Thanks Martin!
scrablevision2
Does your software have encryption included?
Can you explain us, what you mean specifically?
