Topic "error caused by message printed from startup script"
maple_243
2 weeks ago I could log into the server with no problem. But Now I get an error,
Received too large (1265200236 B) SFTP packet. Max supported packet size is 102400 B.
The error is typically caused by message printed from startup script (like .profile). The message may start with "Kill".
My log file,
Quote:
. WinSCP Version 3.5.6 (Build 213)
. Login time: Sunday, March 28, 2004 3:54:28 PM
. Session name: userName@login.xxxx.fi
. Host name: login.xxxx.fi (Port: 22)
. User name: userName (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Ping type: -, Ping interval: 60 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: D:\everyD\_winSCP\xxxx, Remote directory: /home/io/userName/, Update: Yes, Cache: Yes
. Cache directory changes: Yes, Permanent: Yes
. Looking up host "login.xxxx.fi"
. Connecting to 193.167.x.x port 22
. Server version: SSH-1.99-OpenSSH_3.8p1
. We claim version: SSH-2.0-WinSCP-release-3.5.6
. Host key fingerprint is:
. ssh-rsa 1024 9b:40:38:da:e9:c5:28:9f:96:79:32:89:c0:xx:xx:xx
! Using username "userName".
. Server prompt (Password: )
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
. Server sent command exit status 137
. Attempt to close connection due to fatal exception:
* Received too large (1265200236 B) SFTP packet. Max supported packet size is 102400 B.
* The error is typically caused by message printed from startup script (like .profile). The message may start with "Kill".
. Closing connection.
* (ESshFatal) Cannot initialize SFTP protocol. Is the host running a SFTP server?
Please help me on this!
maple_243
The problem was on the server side, they have fixed it.
I discovered that other users were experiencing the same problem too.
Please post here if you know the cause of this, to help other users.
Cheers
Please read the F.A.Q.
For details about error message "Cannot initialize SFTP protocol. Is the host running a SFTP server?" see:
http://winscp.net/eng/docs/message_cannot_initialize_sftp_protocol
