Topic "gpg command not run - gpg --gen-key - how generate gpg key?"
step8601
hi
been trying to run some gpg commands through the terminal but no luck
is it the case that you cannot run any commands at all that need user input?
if yes, do you have any favorite terminal programs?
thanks
scanreg
step8601 wrote:
hi
thanks
Same here
Is WinSCP limited in its terminal capabilities?
Please read documentation:
http://winscp.net/eng/docs/remote_command#limitations
scanreg
Quote:
WinSCP does not support commands that require terminal emulation or user input.
Okay, no prob, thanks for the reply, and thanks for winscp, a great great program
