Topic "Loosing connection to local hard drive after reconnecting .."
(First - your text entry window does not allow entering text after using space of that input box: it moves cursor and new text lower than the text window bottom line. (I use the MS Word to write all this)
and : all your requested information covers that space
Second - all your requested information, honestly, makes me think if I am really wanted to report anything ...)
WinSCP version - 5.0.7 (build 2268)
OS - Windows -7 Enterprise
Session protocol = SSH-2
SSH implementation = OpenSSH_5.8
Encryption algorithm = blowfish
Compression = No
File transfer protocol = SFTP-3
GUI, Commander
Invalid access to memory
OK Help
About the problem:
It is happening consistently, not just one occurrence.
FTP session is opened (successfully, works fine...)
Connection disappeared (usually I disconnect laptop from base station and connecting again at home) - if now I reconnect it would be no problem.
Connecting to internet, but not to opened by WinSCP server
Disconnecting AGAIN
Connected to internet second time (Now the WinSCP has 2 message about the connection lost and offer to reconnect!)Here is the error message:
Network error: Software caused connection abort
OK Reconnect Help
Now trying to reconnect shows the error something about E: drive connection (E: is DVD-drive)
After clicking OK (on reconnect)remote connection is showed fine, but local panel is empty!
WinSCP must be closed and opened again.
Inconvenience is that the opened from remote server files are losing the connection.
I did try to ftp one file (right now) to see if internally it still able to connect, and copying-box shows 100% is copied, but cant be completed (probably reasonable as it could not place result anywhere.)
Worse is impossible to close that copy-box and the WinSCP!!
Finally, I am only able to close it from Task-Manager.
