Topic "Connecting with .ppk private key to a SFTP"
AlLeX_
I need to connect to a SFTP server with a private .ppk key. I can connect with no problems with WinSCP GUI.
I am trying with CLI, but now luck. Could you, please, tell me the exact syntax of the command I must use.
AlLeX_
Here it is the picture, so the things are clearer Smile
How to specify the private key with CLI, this is not the Host key, right ?
Description: WinSCP Login
What do you mean by CLI? Scripting?
Use -privatekey= switch of open commmand:
http://winscp.net/eng/docs/scriptcommand_open
If you really mean command-line, there's equivalent /privatekey= command-line parameter:
http://winscp.net/eng/docs/commandline#session
AlLeX_
Thanks, I will try it.
Yes, cli is command line interface!
AlLeX_
1. the simple commands winscp.com /command "open user@sftp_srv" /privatekey=c:\private.ppk or winscp.exe /console.... work perfectly.
2. But I want to use a script file
winscp.com /script=script_file.txt and in the script_file.txt I specify the private key
open user@sftp_srv /privatekey=..... This does not workand the error is "Too many parameters with open". Appearently the /privatekey switch here is the problem because without it, the script starts to open the session - of course it fails.
Is there a way to use /privatekey within a script file ?
There should be a dash, not slash before privatekey, i.e. -privatekey=
See http://winscp.net/eng/docs/scriptcommand_open
AlLeX_
I have decided to usе a saved session.
Thank you!
