Topic "Automation - powershell - host key not verified"
JeremyNac
Hi everybody,
I'm new to Winscp.
I try to send file automatically with Winscp on a SFTP server.
When I connect manually with the GUI, I have no problem : I can connect, send files, get files, ...
But now, I want to send file automatically (with schedulded tasks) using Powershell.
To do it, I execute this command :
PS c:\Program Files (x86)\WinSCP> powershell c:\myscript.ps1
Here is the content of my script to send the file automatically.
try
    # Load WinSCP .NET assembly
    [Reflection.Assembly]::LoadFrom("WinSCP.dll") | Out-Null
    # Setup session options
    $sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
    $sessionOptions.HostName = "xxx.xxx.xxx.xxx"
    $sessionOptions.UserName = "my_user"
    $sessionOptions.Password = "my_password"
    $SessionOptions.SshPrivateKeyPath = "c:\my_private_key.ppk"
    $sessionOptions.SshHostKeyFingerprint = "ssh-rsa 1023 95:5d:61:f4:c3:bb:1d:54:29:0e:55:6d:e5:c1:c8:26"
    try
        # Connect
        # Upload files
        $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
        $transferResult = $session.PutFiles("c:\testfile.txt", "./", $FALSE, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
        foreach ($transfer in $transferResult.Transfers)
            Write-Host ("Upload of {0} succeeded" -f $transfer.FileName)
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
The result of this script is :
The host key was not verified
I'm disappointed, because I really don't know how to do.
Can somebody help me?
Thank you.
I'm still looking for.
Set Session.SessionLogPath and inspect the log for host keys.
Post the log, if it does not help.
vik
i want to upload files everyday to SFTP CLIENT USING POWERSHELL AND THEN AUTOMATE IT USING TASK SHEDULER.....IM NEW TO THIS KIND OF TASKS.......COULD YOU PLS HELP ME OUT....I TRIED SOME OF THE SCRIPTS BUT I DONT KNOW ITS NOT WORKING AT ALL....CAN ANYONE HELP ME OUT PLS.
Start a new thread, show us what you have tried and what problems are you facing.
