Topic "Error using GetFiles"
canuszczyk
I'm getting an error downloading a file from an ftp site.
The file is in a subfolder.
Please see the attached session log...
sessionlog.txt (14.39 KB) [Download]
Description: (none)
sebasv
Same as mine 1 hour earlier.
I tried to search the forum......
canuszczyk
I kind of got it to work. I ended up changing folders on the remote end using the session.executecommand method to call CWD. Then I had to get a list of files in the folder. I was then able to get files. Not sure why, but this works.
sebasv
Using CWD works yes, thanks.
Im not using double folders so i can do this with:
Quote:
Dim Path() As String
Dim SourceFile As String
If source.Contains("/") Then
Path = source.Split("/")
SourceFile = Path(1)
Dim command As String = "CWD" & Path(0)
session.ExecuteCommand(command)
Else
SourceFile = source
End If
transferResult = session.GetFiles(SourceFile, dest)
This bug is tracked here:
http://winscp.net/tracker/show_bug.cgi?id=926
