Topic "keepuptodate access denied whith my documents subfolders"
faridux31
I use Windows Vista, I try to run backup of My Documents folder to a sftp server in command line:
open sessionforlivebackup
cd livedata
lcd c:\users\faridux\documents
keepuptodate -delete
once winscp has finished to upload new/modified files and delete obsolete files,
it exits with the message Error 5, Access denied because it cannot access to c:\users\faridux\documents\My musics
When I browse c:\users\faridux\documents in windows explorer I do not see any folder called My musics, If I display hiden files I do not see it neither
Is it possible to exclude this hidden mount point to be taken into account by winscp
Note the problem is the same with the GUI
Thanks for your help
You can use -filemask (or equivalent option is earlier versions of WinSCP) to exclude any file/folder you want.
faridux31
thank you for your prompt reply
I will upgrade and use filemask as described in the doc then
I should have check it first Surprised)
