Topic "winscp syntax help"
rookie19
Can you tell me what I am doing wrong? The code below is not working:
"E:\Program Files\WinSCP\WinSCP.exe"
option batch on
open username@xxx.edu
cd /cygdrive/E/vol1/dev
put e:\Reporting\dir\test_report.txt
close
Sorry, your post does not include enough information.
Please read how to troubleshoot problems with WinSCP. If it turns out that you are not able to help yourself, read how to ask for support or report bugs efficiently, so others can help you.
rookie19
More information:
How can I combine two .bat files into one?
1. I have a .bat file that has the following syntax:
"E:\Program Files\WinSCP\WinSCP.exe" /script=E:\test folder\test_file.txt
2. The next file is the test_file.txt that has the following syntax:
option batch on
open user@xxx.xx
cd /cygdrive/E/some directory
put e:\some directory\some file*
close
I want to combine the syntax from both files instead of having to run the .bat file that calls to the test_file.
You can use /command instead of /script to provide your script commands to WinSCP as command-line arguments rather than via script file.
http://winscp.net/eng/docs/scripting#using_scripting
