Topic "copy and remove files to two ftp servers"
I'm trying to use a script that copy a csv files to an ftp server then move the same files to other ftp server.
Main problem is that log file generated by command contain only info about first connection and about second connection log file (with the same name) is located in lcd command path.
How can I solve this issue (having one log file for both connections)?
Ex(batch file)
@echo off
path=c:\;c:\windows;c:\windows\system32;C:\Program Files\WinSCP
IF EXIST daily_d.log DEL daily_d.log /console /script=taskD.txt /log=daily_d.log
Ex (script tasD.txt)
# Automatically abort script on errors
option batch continue
open x
lcd c:\prognoza\outgoing
put *.csv /prognoza_nou/
open y
put -delete *.csv /
# Disconnect
# Exit WinSCP
Use full path to a log file.
I already split in two scripts the transfer to ftp servers. Thanks for your reply.
