Topic "Scripting...Daylight savings change now downloads everything"
My first post Smile
Now that DST has kicked in here in the UK my simple script downloads everything every time it is run. It didn't do this yesterday.
All it does is sync the files from a remote FTP server to my local drive but it constantly downloads again and again.
I'm sure I must be doing something wrong but having had a good look through the docs I can't find it.
Please, someone point me in the right direction Smile
Version 5.1.0 (Build 2625) - which I have just downloaded and tested against.
The command line:
winscp /script=<scriptname>.txt
The script:
# Automatically answer all prompts negatively not to stall the script on errors
option batch on
# Connect using a password
open <user/password/etc> -passive=on
# Change remote directory
cd "<server path>"
# Force binary mode transfer
option transfer binary
synchronize local "<path>" -mirror
# Disconnect
# Exit WinSCP
I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
