Topic "File names change with if the file names contain '3'"
sammiesmiles
Hi I am using WinSCP 5.1.0 (build 2625) on Win XP.
I use WinSCP to connect to a Kubuntu server.
I found an issue, if i copy a file, for example, 'File321.txt' to my computer, the copied filenames becomes 'File%3321.txt' in the folder.
Is this a common issue in WinSCP, or something with the Kubuntu server?
Cheers,
Sam
It's probably something with your configuration.
Please post here an export from
HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\CopyParam
And try to delete value LocalInvalidChars.
sammiesmiles
It works properly now, cheers. Razz
