Topic "Trouble using .NET session.fileexist with FTP protocol"
jandv
The code I developed works fine with vsftpd, while it doesn't with Titan FTP Server v9.12
Before uploading files, I check with the Session.FileExists method if the file already exists. On Titan FTP Server, the first call succeeds, while the second call stops with a SessionLocalExeption: Element "group" not found in the log-file.
WinSCP Version 5.1.1
1211081519_Debug.log (115.41 KB) [Download]
Description: (none)
201211_Sessions.log (4.47 KB) [Download]
Description: (none)
jandv
I forgot to mention the same code works fine with the SFTP protocol on the same Titan FTP server.
I do not see any listing in the response to the MLST command:
> 2012-11-08 15:19:54.945 MLST MEIV1211081519.zip
< 2012-11-08 15:19:54.961 250-MLST /MEIV1211081519.zip
---- listing should be here ----
< 2012-11-08 15:19:54.961 250 command successful.
You should contact Tital support.
jandv
Thanks a lot Martin for this very quick reaction.
I'll check with Titan support.
Anyway, can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
JanDV
I sent you a mail today 14th November 12:00
JanDV
Today I sent you a new mail with the answer of Titan support.
JanDV
Today I sent you a second mail with an answer (additional information) of Titan support.
JanDV
The problem is solved after the update to Titan FTP Server version 9.13 Build 1623.
Thanks a lot for your very adequate and quick support.
