Topic "SSL_connect: error in SSLv2/v3 read server hello A"
Spamator
HEllo All,
I would like use Keepass 2.20.1 and its plugin IOProtocoleExt 1.6 to connect to my database via FTPS.
Normally it uses the port 990 but for firewall security reasons, i have to use port 22.
On port 990 it perfectly works, but for the port 22 it is not the same
Here is the WinScp Error message :
Can't establish SSL connection
Disconnected from server
Connection failed.
I tested with success with Filezilla.
The FTPS is a IIS 7.5 running on a server 2008 R2
The certificate is a self signed one.
If someone has an idea
regards
Please attach complete log file both from WinSCP and Filezilla
Spama
thank you for your reply.
You can find in attached Filezilla log, and winscp.
regards
filezilla.txt (1.77 KB) [Download]
Description: (none)
log_debug2_winscp.log (2.66 KB) [Download]
Description: (none)
Spama
Any news about it ?
regards
Spama
Hello i need some news about it because it is blocking for a project.
WinSCP is integrated with Keepass with the plugin IOProtocole ext.
And as it seems to be a bug i need to know what is the status of it.
Do I have to wait or i can cancel it ?
thank you !
Spama
Is my request too hard ?
It looks like you are using Explicit TLS with Filezilla, while Implicit SSL/TLS with WinSCP.
Try using Explicit TLS with WinSCP too.
Spama
Indeed ! Smile
thks a lot !
