Topic "Jumplist problems when using .ini config flag"
splic
I'm having the following issue on WinSCP:
When using the ini flag (/ini=%appdata%/WinSCP/WinSCP.ini) in my pinned shortcut my jumplist items do not use the correct saved session and try connecting using the name stored in the jumplist.
If I have a saved session in both the registry and .ini file it connects correctly.
Am I correct in assuming that the jumplist shortcut is not using my ini flag specified in the pinned shortcut (%appdata%\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar)?
If so, is there a registry entry that can correctly point to my .ini file? If not, is there an .ini setting I can keep in a read-only .ini in the install dir that points to the correct, writable .ini or some other solution?
Thank you
System config:
    WinSCP 5.1.1 (Build 2735)
    Windows 7 SP1
    SFTP Stored Sessions
    Taskbar Shortcut "Target":
    "C:\Program Files (x86)\WinSCP\WinSCP.exe" /ini=%appdata%/WinSCP/WinSCP.ini
Thanks for your post.
http://winscp.net/tracker/show_bug.cgi?id=941
