Topic "Sync to server"
Steve2106
Hi There,
I have my script working sort of.
I want to use a file filter to upload files to remote server.
Below is my script but it reports "nothing to syncronize"
option batch on
open CarHireBackup
option transfer binary
get C:\StevesStuff\CarHire14112012\*.Dat /testremote/*.Dat
synchronize remote C:\StevesStuff\CarHire14112012\*.Dat testremote\*.Dat
What is wrong with this script?
I appreciate your help.
Best Regards,
Steve
gman804
Just an fyi - i always use a full path and put any directory with a space in it in quotes e.g. "c:\Documents and Settings\" or "/cygdrive/c/Documents and Settings/"
your command, "get C:\StevesStuff\CarHire14112012\*.Dat /testremote/*.Dat", should be "get </remote location/file> [local directory\renamefile.renameext]"
so your line should be "get /testremote/*.Dat C:\StevesStuff\CarHire14112012\"
I removed the *.dat from the end of C:\StevesStuff\CarHire14112012\ because you're not renaming files.
your command, "synchronize remote C:\StevesStuff\CarHire14112012\*.Dat testremote\*.Dat", should be
"synchronize remote C:\StevesStuff\CarHire14112012\ /testremote/ -filemask="*.Dat"
more than one file extension can be separated by a "; " e.g. "*.Dat; *.txt"
make sure that it's .Dat that you want and not .dat bc it may be case-sensitive, also unix uses a forward-slash, "/"
Steve2106
Hi GMan,
Thanks for the reply.
I'll give that a try when I get back to my test PC.
Best Regards,
Steve.
Steve2106
Hi There,
I cannot get this to work.
If I explain what I want to do maybe someone can show me the way.
From a directory on my PC I want to get all files with a .Dat extention and upload them to a backup directory on a server.
Would anyone know the script code to do that.
Below is the script I am trying to use and it nearly works:
option batch on
open CarHireBackup
get C:\StevesStuff\CarHire14112012\*.Dat /CarHireBackUp/
synchronize remote C:\StevesStuff\CarHire14112012\ /CarHireBackUp/ -filemask="*.Dat"
I don't want to syncronise just upload.
Thanks for your help.
Best Regards,
Steve.
Steve2106
Hi There,
I have tried a couple of other things and they look more successful but I still do not see the file.
You can see my log & script code below.
This is the log returned:
. 2012-11-21 14:38:58.655 Using FTP protocol.
. 2012-11-21 14:38:58.655 Doing startup conversation with host.
> 2012-11-21 14:38:58.655 PWD
< 2012-11-21 14:38:58.781 257 "/StWilson" is current directory.
. 2012-11-21 14:38:58.781 Changing directory to "CarHireBackUp".
> 2012-11-21 14:38:58.781 CWD CarHireBackUp
< 2012-11-21 14:38:58.908 250 CWD command successful.
. 2012-11-21 14:38:58.908 Getting current directory name.
> 2012-11-21 14:38:58.908 PWD
< 2012-11-21 14:38:59.038 257 "/StWilson/CarHireBackUp" is current directory.
. 2012-11-21 14:38:59.038 Startup conversation with host finished.
< 2012-11-21 14:38:59.038 Script: Active session: [1] CarHireBackup
> 2012-11-21 14:38:59.038 Script: option transfer binary
< 2012-11-21 14:38:59.038 Script: transfer binary
> 2012-11-21 14:38:59.039 Script: Put C:\StevesStuff\CarHire14112012\BrokenWindow.TXT \CarHireBackUp\
. 2012-11-21 14:38:59.039 Copying 1 files/directories to remote directory "/StWilson/CarHireBackUp"
. 2012-11-21 14:38:59.039 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask: \CarHireBackUp\
. 2012-11-21 14:38:59.039 TM: B; ClAr: No; CPS: 0; InclM:
. 2012-11-21 14:38:59.039 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2012-11-21 14:38:59.039 File: "C:\StevesStuff\CarHire14112012\BrokenWindow.TXT"
. 2012-11-21 14:38:59.042 Copying "C:\StevesStuff\CarHire14112012\BrokenWindow.TXT" to remote directory started.
. 2012-11-21 14:38:59.042 Binary transfer mode selected.
. 2012-11-21 14:38:59.043 Starting upload of C:\StevesStuff\CarHire14112012\BrokenWindow.TXT
> 2012-11-21 14:38:59.043 TYPE A
< 2012-11-21 14:38:59.175 200 Type set to A.
> 2012-11-21 14:38:59.176 PASV
< 2012-11-21 14:38:59.312 227 Entering Passive Mode (174,36,218,226,19,156).
> 2012-11-21 14:38:59.312 LIST
< 2012-11-21 14:38:59.579 125 Data connection already open; Transfer starting.
. 2012-11-21 14:38:59.581 11-21-12 06:53AM 2048 CarHireBackUp
. 2012-11-21 14:38:59.581 11-16-12 07:55AM <DIR> testremote
< 2012-11-21 14:38:59.914 226 Transfer complete.
> 2012-11-21 14:38:59.915 TYPE I
< 2012-11-21 14:39:00.038 200 Type set to I.
> 2012-11-21 14:39:00.038 PASV
< 2012-11-21 14:39:00.166 227 Entering Passive Mode (174,36,218,226,19,157).
> 2012-11-21 14:39:00.166 STOR CarHireBackUp
< 2012-11-21 14:39:00.442 125 Data connection already open; Transfer starting.
< 2012-11-21 14:39:00.770 226 Transfer complete.
. 2012-11-21 14:39:00.770 Upload successful
> 2012-11-21 14:39:00.770 Script: exit
. 2012-11-21 14:39:00.770 Script: Exit code: 0
. 2012-11-21 14:39:00.773 Disconnected from server
This is my Script:
option batch on
open CarHireBackup
I would appreciate if anyone can see why the file is not showing.
Best Regards,
Steve.
Where do you want your files to end up? In /StWilson/CarHireBackUp?
option batch on
open CarHireBackup
put C:\StevesStuff\CarHire14112012\BrokenWindow.TXT /StWilson/CarHireBackUp
ls /StWilson/CarHireBackUp
Note the "ls" at the end will list the target directory, so that we can see, if the file is there or not.
Steve2106
Hi prikryl,
Thanks for your reply.
I have got this working now. Thankyou.
I have one other important request.
How do I add the date and time to the file names?
This is because I want to create the backup files but not overwrite what is already there.
So I need BrokenWindow.TXT to be BrokenWindow20121122_1450.TXT etc.
Can that be done?
Thanks again for your help, I really appreciate it.
Best Regards,
Steve.
WinSCP cannot do this for you. You have to prepate the script in advance with the timestamp. Possibly using some scripting language.
There an example for this:
http://winscp.net/eng/docs/script_download_timestamped_filename
Steve2106
Hi prikryl,
Thanks for the quick reply.
Can the WinSCP script be run in a .bat file?
I have some code that appends the date & time to files for a different purpose but I could try to use that.
I am not sure how to code the script that WinSCP needs in a .bat file.
Do you have any pointers?
Best Regards,
Steve.
Of course.
See http://winscp.net/eng/docs/guide_automation#script_file
