Topic "Not able to get list of files in XML log"
appu
im trying to get a list of remote files in an xml log, but the log doesnt contain the list ...
im using a batch file to run commands. bat file contains below code :
"c:\Program Files\WinSCP\WinSCP.exe" /script=C:\appu\testscript.txt /log=C:\appu\apputest.xml
testscript.txt contains below code :
option batch abort
open sftp://****:****@**.**.**.***:**
ls /app/kinle/env2/archive/to/jap1/*.zip
apputest.xml is loaded with below log below the acces granted and other login stuff :
. 2012-11-24 17:08:44.584 --------------------------------------------------------------------------
. 2012-11-24 17:08:44.584 Using SFTP protocol.
. 2012-11-24 17:08:44.584 Doing startup conversation with host.
> 2012-11-24 17:08:44.584 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2012-11-24 17:08:44.600 Type: SSH_FXP_VERSION, Size: 124, Number: -1
. 2012-11-24 17:08:44.600 SFTP version 3 negotiated.
. 2012-11-24 17:08:44.600 Unknown server extension posix-rename@openssh.com=1
. 2012-11-24 17:08:44.600 Unknown server extension statvfs@openssh.com=2
. 2012-11-24 17:08:44.600 Unknown server extension fstatvfs@openssh.com=2
. 2012-11-24 17:08:44.600 Unknown server extension hardlink@openssh.com=1
. 2012-11-24 17:08:44.600 We believe the server has signed timestamps bug
. 2012-11-24 17:08:44.600 We will use UTF-8 strings for status messages only
. 2012-11-24 17:08:44.600 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2012-11-24 17:08:44.600 Getting current directory name.
. 2012-11-24 17:08:44.600 Getting real path for '.'
> 2012-11-24 17:08:44.600 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2012-11-24 17:08:44.600 Type: SSH_FXP_NAME, Size: 49, Number: 16
. 2012-11-24 17:08:44.600 Real path is '/home/puliurve'
. 2012-11-24 17:08:44.600 Startup conversation with host finished.
. 2012-11-24 17:08:44.600 Listing directory "/app/kinle/env2/archive/to/jap1/*.zip".
> 2012-11-24 17:08:44.600 Type: SSH_FXP_OPENDIR, Size: 51, Number: 267
< 2012-11-24 17:08:44.600 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2012-11-24 17:08:44.600 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2012-11-24 17:08:44.600 Type: SSH_FXP_NAME, Size: 12747, Number: 524
> 2012-11-24 17:08:44.600 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2012-11-24 17:08:44.615 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2012-11-24 17:08:44.615 Status/error code: 1
> 2012-11-24 17:08:44.615 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2012-11-24 17:08:44.615 Closing connection.
. 2012-11-24 17:08:44.615 Sending special code: 12
. 2012-11-24 17:08:44.615 Sent EOF message
Are you using the latest version of WinSCP?
