Topic "Problems with instalation"
Michal
I have installed WinSCP 3.5.6 and Far plugin but it is not working. Far vesion 1.65. Configuration menu for WinSCP is empty. I can see my sessions, but can't connect. It generates Error:EAccessViolation. WinSCP is working.
WinSCP plugin supports only the latest version of FAR (1.7 beta 5).
Volker
When I did this upgrade, FTP didn't work anymore.
My solution was to continue using the FTP plugin that came with 1.65 together with 1.7 and the WinSCP plugin.
So just in case one should backup the previous version of FAR before upgrading.
What FTP plugin do you use? I use Far Navigator (former ProxyFTP), which works fine in FAR 1.7 beta 5.
Volker
In both cases (1.65 and 1.7) it came with FAR, not sure about the relation to other products.
My guess would be that the make process that puts together the FAR archive included some wrong (old?) files instead of the matching ones.
It is not a bug related to WinSCP in any way, I tried this FAR upgrade before I installed WinSCP - and as the FAR 1.7 is beta, problems like this can easily happen.
System was WinNT4 SP6 on a P3/600 Katmai. Maybe that was just too ancient and the new FTP plugin didn't like it ;-)
The WinSCP plugin came just in time btw., most servers I am using block FTP now - thanks a lot !
