Topic "Handling of Ctrl+Cursor Left/Right in "Open directory"dialog"
larsen
I pasted this string into the "open directory" dialog: /opt/atlassian/jira/bin/start-jira.sh
Now, I want to remove the filename "start-jira.sh" to open the directory.
I hold Ctrl and press Cursor left to get to the beginning of the filename.
With the first LeftCursor press, the cursor jumps to the end of the dash
With the second LeftCursor press, the cursor jumps to the beginning of the dash.
With the third LeftCursor press, the cursor jumps to the beginning of the whole string.
It would be useful if the cursor would also stop at the end of the slashes, so you could easily position the cursor at the beginning of the filename or each part of the directory name.
Lars
http://winscp.net/tracker/show_bug.cgi?id=954
I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
larsen
Thx! Works as expected.
