Topic "login timeout with ftps (pure-ftp server)"
jseymour
I am a longtime user of winscp. We have secured our ftp server with ssl using the pure-ftp server. I had a user recently that complained that if they typed in the password they would get a time out message. At the time I was still on the 4x version and could not duplicate the issue. I discovered that the user was using the new 5x version which I upgraded to and the issue happens regularly.
We are using ssl explicit encryption
The error I get is:
Timeout detected.
Connection failed.
User ftpdown2 OK. Password required
I had 5.1.1 installed and it seemed that if I copy and pasted the password it ould not timeout - now with 5.1.2 it seems to never work.
Ithe 4x version never had a problem and I can connect without issues using filezilla. No timeouts are set on the server - except a 15 minute idle session timeout.
Please attach a somplete session log file both using successfull session in WinSCP 4 and unsuccessful using WinSCP 5. Thanks.
jseymour
Thanks for the reply. Session logs are attached.
ftpdown2@ftp.xxxx.xxx-512.log (2.6 KB) [Download]
Description: (none)
ftpdown2@ftp.xxx.xxx-439.log (4.81 KB) [Download]
Description: (none)
Thanks.
http://winscp.net/tracker/show_bug.cgi?id=955
I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
jseymour
Thanks prikryl,
Tested and seems to now work as expected. Very Happy
John
prikryl wrote:
Thanks.
