Topic "How to Avoid "MLSD" - Directory Listing During Session Open?"
austinow
Currently I am working in a very large size directory that contain more than 100 thousands of files.
How can I avoid the MLSD on the Directory Listing During the Session Open.
I am writing in Visual c# .
Example from my session log file below:
> 2012-12-06 12:02:29.191 MLSD
< 2012-12-06 12:02:29.799 150 Opening ASCII mode data connection for MLSD
Below is my Session Log file:
. 2012-12-06 12:02:14.948 --------------------------------------------------------------------------
. 2012-12-06 12:02:14.948 WinSCP Version 5.1.1 (Build 2735) (OS 6.1.7600)
. 2012-12-06 12:02:14.948 Configuration: nul
. 2012-12-06 12:02:14.948 Local account: PK111\Admin
. 2012-12-06 12:02:14.964 Working directory: C:\Users\Admin\AppData\Local\Apps\2.0\3HORG67E.AG5\7BT6EZ85.GZB\ftp_..tion_89e3500776d96da4_0001.0000_994546233ae42139
. 2012-12-06 12:02:14.964 Command-line: "C:\Program Files\WinSCP\winscp.exe" /xmllog="C:\Users\Admin\AppData\Local\Temp\tmp7BD9.tmp" /xmlgroups /nointeractiveinput /dotnet=511 /ini=nul /log="C:\\wamp\\www\\source\\Session_log.log"  /console /consoleinstance=_4836_985
. 2012-12-06 12:02:14.964 Time zone: Current: GMT+8, Standard: GMT+8, DST: GMT+9, DST Start: 12/30/1899, DST End: 12/30/1899
. 2012-12-06 12:02:14.964 Login time: Thursday, December 06, 2012 12:02:14 PM
. 2012-12-06 12:02:14.964 --------------------------------------------------------------------------
. 2012-12-06 12:02:14.964 Session name: ftser@tag.gotdns.com (Ad-Hoc session)
. 2012-12-06 12:02:14.964 Host name: tag.gotdns.com (Port: 121)
. 2012-12-06 12:02:14.964 User name: ftser (Password: Yes, Key file: No)
. 2012-12-06 12:02:14.964 Tunnel: No
. 2012-12-06 12:02:14.964 Transfer Protocol: FTP
. 2012-12-06 12:02:14.964 Ping type: C, Ping interval: 30 sec; Timeout: 120 sec
. 2012-12-06 12:02:14.964 Proxy: none
. 2012-12-06 12:02:14.964 FTP: FTPS: None; Passive: Yes [Force IP: A]
. 2012-12-06 12:02:14.964 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2012-12-06 12:02:14.964 Cache directory changes: Yes, Permanent: Yes
. 2012-12-06 12:02:14.964 DST mode: 1
. 2012-12-06 12:02:15.010 Connecting to tag.gotdns.com:121 ...
. 2012-12-06 12:02:15.369 Connected with tag.gotdns.com:121. Waiting for welcome message...
< 2012-12-06 12:02:20.704 220 ProFTPD 1.3.4a Server (Debian) [::ffff:192.168.0.22]
> 2012-12-06 12:02:20.704 USER ftser
< 2012-12-06 12:02:20.985 331 Password required for ftser
> 2012-12-06 12:02:20.985 PASS ******
< 2012-12-06 12:02:23.528 230 User ftser logged in
> 2012-12-06 12:02:23.528 SYST
< 2012-12-06 12:02:23.840 215 UNIX Type: L8
> 2012-12-06 12:02:23.840 FEAT
< 2012-12-06 12:02:24.136 211-Features:
< 2012-12-06 12:02:24.136  LANG en-US.UTF-8;en-US*
< 2012-12-06 12:02:24.136  MDTM
< 2012-12-06 12:02:24.136  MFMT
< 2012-12-06 12:02:24.136  TVFS
< 2012-12-06 12:02:24.136  UTF8
< 2012-12-06 12:02:24.136  MFF modify;UNIX.group;UNIX.mode;
< 2012-12-06 12:02:24.136  MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
< 2012-12-06 12:02:24.136  SITE MKDIR
< 2012-12-06 12:02:24.136  SITE RMDIR
< 2012-12-06 12:02:24.136  SITE UTIME
< 2012-12-06 12:02:24.136  SITE SYMLINK
< 2012-12-06 12:02:24.152  REST STREAM
< 2012-12-06 12:02:24.152  SITE COPY
< 2012-12-06 12:02:24.152  SIZE
< 2012-12-06 12:02:24.152 211 End
> 2012-12-06 12:02:24.152 OPTS UTF8 ON
< 2012-12-06 12:02:24.417 200 UTF8 set to on
. 2012-12-06 12:02:24.417 Connected
. 2012-12-06 12:02:24.417 --------------------------------------------------------------------------
. 2012-12-06 12:02:24.417 Using FTP protocol.
. 2012-12-06 12:02:24.417 Doing startup conversation with host.
> 2012-12-06 12:02:24.417 PWD
< 2012-12-06 12:02:24.745 257 "/" is the current directory
. 2012-12-06 12:02:24.745 Getting current directory name.
. 2012-12-06 12:02:24.745 Startup conversation with host finished.
< 2012-12-06 12:02:24.745 Script: Active session: [1] ftser@tag.gotdns.com
> 2012-12-06 12:02:25.182 Script: put  -nopermissions -preservetime -transfer="binary" -- "C:\\wamp\\www\\source\\cam1\006E060214F1(Cam 124)_0_20121206120126_43998.jpg" "/cam1/"
. 2012-12-06 12:02:25.197 Copying 1 files/directories to remote directory "/cam1/"
. 2012-12-06 12:02:25.197   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2012-12-06 12:02:25.197   TM: B; ClAr: No; CPS: 0; InclM:
. 2012-12-06 12:02:25.197   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2012-12-06 12:02:25.197 File: "C:\\wamp\\www\\source\\cam1\006E060214F1(Cam 124)_0_20121206120126_43998.jpg"
. 2012-12-06 12:02:25.197 Copying "C:\\wamp\\www\\source\\cam1\006E060214F1(Cam 124)_0_20121206120126_43998.jpg" to remote directory started.
. 2012-12-06 12:02:25.197 Binary transfer mode selected.
. 2012-12-06 12:02:25.197 Starting upload of C:\\wamp\\www\\source\\cam1\006E060214F1(Cam 124)_0_20121206120126_43998.jpg
> 2012-12-06 12:02:25.197 CWD /cam1/
< 2012-12-06 12:02:25.494 250 CWD command successful
> 2012-12-06 12:02:25.494 PWD
< 2012-12-06 12:02:25.774 257 "/cam1" is the current directory
> 2012-12-06 12:02:25.774 TYPE A
< 2012-12-06 12:02:28.910 200 Type set to A
> 2012-12-06 12:02:28.910 PASV
< 2012-12-06 12:02:29.191 227 Entering Passive Mode (95,139,16,114,132,38).
. 2012-12-06 12:13:56.294 modify=20121117192845;perm=flcdmpe;type=cdir;unique=B302U541B8;UNIX.group=1000;UNIX.mode=0775;UNIX.owner=1000; .
. 2012-12-06 12:13:56.294 modify=20121129134702;perm=flcdmpe;type=pdir;unique=B302U547BE;UNIX.group=1000;UNIX.mode=0755;UNIX.owner=1000; ..
. 2012-12-06 12:13:56.294 modify=20121129172658;perm=adfrw;size=6428;type=file;unique=B302U57C76;UNIX.group=1000;UNIX.mode=0644;UNIX.owner=1000; 006E060214F1(Cam 124)_0_20121130012658_27672.jpg
Below is my Debug log:
[2012-12-06 12:02:12.249Z] [0001] Executing Assembly: WinSCP, Version=1.0.2.2735, Culture=neutral, PublicKeyToken=b5f19f5762436b89; Path: C:\Users\Admin\AppData\Local\Apps\2.0\3HORG67E.AG5\7BT6EZ85.GZB\ftp_..tion_89e3500776d96da4_0001.0000_994546233ae42139\WinSCP.DLL; Location: C:\Users\Admin\AppData\Local\Apps\2.0\3HORG67E.AG5\7BT6EZ85.GZB\ftp_..tion_89e3500776d96da4_0001.0000_994546233ae42139\WinSCP.dll; Product: 5.1.1.0
[2012-12-06 12:02:12.421Z] [0001] Entry Assembly: FTP_Upload, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
[2012-12-06 12:02:12.436Z] [0001] Operating system: Microsoft Windows NT 6.1.7600.0
[2012-12-06 12:02:12.468Z] [0001] User: Admin@PK111@PK101; Interactive: True
[2012-12-06 12:02:12.468Z] [0001] Runtime: 2.0.50727.4971
[2012-12-06 12:02:12.514Z] [0001] Console encoding: Input:  United States (437); Output:  United States (437)
[2012-12-06 12:02:12.514Z] [0001] Working directory: C:\Users\Admin\AppData\Local\Apps\2.0\3HORG67E.AG5\7BT6EZ85.GZB\ftp_..tion_89e3500776d96da4_0001.0000_994546233ae42139
[2012-12-06 12:02:12.826Z] [0001] CallstackAndLock..ctor entering
[2012-12-06 12:02:12.842Z] [0001]   Session.GetTempPath entering
[2012-12-06 12:02:12.842Z] [0001]     Temporary folder: C:\Users\Admin\AppData\Local\Temp\
[2012-12-06 12:02:12.842Z] [0001]     Temporary file: C:\Users\Admin\AppData\Local\Temp\tmp7BD9.tmp - Exists [True]
[2012-12-06 12:02:12.842Z] [0001]   Session.GetTempPath leaving
[2012-12-06 12:02:12.842Z] [0001]   ExeSessionProcess..ctor entering
[2012-12-06 12:02:12.842Z] [0001]     ExeSessionProcess.GetExecutablePath entering
[2012-12-06 12:02:12.842Z] [0001]       Executable not found in C:\Users\Admin\AppData\Local\Apps\2.0\3HORG67E.AG5\7BT6EZ85.GZB\ftp_..tion_89e3500776d96da4_0001.0000_994546233ae42139\winscp.exe
[2012-12-06 12:02:12.842Z] [0001]       Executable not found in C:\Program Files\WinSCP\winscp.exe
[2012-12-06 12:02:12.842Z] [0001]     ExeSessionProcess.GetExecutablePath leaving
[2012-12-06 12:02:12.842Z] [0001]     EXE executable path resolved to C:\Program Files\WinSCP\winscp.exe
[2012-12-06 12:02:12.858Z] [0001]     ExeSessionProcess.CheckVersion entering
[2012-12-06 12:02:12.858Z] [0001]       Version of C:\Program Files\WinSCP\winscp.exe is 5.1.1.2735, product WinSCP version is 5.1.1.0
[2012-12-06 12:02:12.858Z] [0001]     ExeSessionProcess.CheckVersion leaving
[2012-12-06 12:02:12.858Z] [0001]   ExeSessionProcess..ctor leaving
[2012-12-06 12:02:12.858Z] [0001]   ExeSessionProcess.Start entering
[2012-12-06 12:02:12.858Z] [0001]     ExeSessionProcess.InitializeConsole entering
[2012-12-06 12:02:12.858Z] [0001]     ExeSessionProcess.InitializeConsole leaving
[2012-12-06 12:02:12.858Z] [0001]     ExeSessionProcess.InitializeChild entering
[2012-12-06 12:02:12.858Z] [0001]       Starting "C:\Program Files\WinSCP\winscp.exe" /xmllog="C:\Users\Admin\AppData\Local\Temp\tmp7BD9.tmp" /xmlgroups /nointeractiveinput /dotnet=511 /ini=nul /log="C:\\wamp\\www\\source\\Session_log.log"  /console /consoleinstance=_4836_985
[2012-12-06 12:02:12.936Z] [0001]       Started process 9152
[2012-12-06 12:02:12.936Z] [0001]     ExeSessionProcess.InitializeChild leaving
[2012-12-06 12:02:12.936Z] [0001]   ExeSessionProcess.Start leaving
[2012-12-06 12:02:12.936Z] [0001]   Command: [option batch on]
[2012-12-06 12:02:12.936Z] [0001]   ExeSessionProcess.ExecuteCommand entering
[2012-12-06 12:02:12.936Z] [0001]   ExeSessionProcess.ExecuteCommand leaving
[2012-12-06 12:02:12.936Z] [0001]   Command: [option confirm off]
[2012-12-06 12:02:12.936Z] [0001]   Command: [option reconnecttime 120]
[2012-12-06 12:02:12.951Z] [0001]   Session.SessionOptionsToOpenArguments entering
[2012-12-06 12:02:12.967Z] [0001]     Session.SessionOptionsToOpenSwitches entering
[2012-12-06 12:02:12.967Z] [0001]     Session.SessionOptionsToOpenSwitches leaving
[2012-12-06 12:02:12.967Z] [0001]   Session.SessionOptionsToOpenArguments leaving
[2012-12-06 12:02:12.967Z] [0001]   Command: [open -passive=1 -timeout=120 "ftp://ftser@tag.gotdns.com:121"]
[2012-12-06 12:02:12.967Z] [0001]   ExeSessionProcess.ExecuteCommand entering
[2012-12-06 12:02:12.967Z] [0001]   ExeSessionProcess.ExecuteCommand leaving
[2012-12-06 12:02:13.060Z] [0003] ExeSessionProcess.ProcessEvents entering
[2012-12-06 12:02:14.932Z] [0003]   ExeSessionProcess.ProcessEvent entering
[2012-12-06 12:02:14.932Z] [0003]     ExeSessionProcess.ProcessInitEvent entering
[2012-12-06 12:02:14.932Z] [0003]     ExeSessionProcess.ProcessInitEvent leaving
[2012-12-06 12:02:14.932Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-12-06 12:02:14.932Z] [0003]     ExeSessionProcess.ProcessTitleEvent entering
[2012-12-06 12:02:14.932Z] [0003]       Not-supported title event [WinSCP]
[2012-12-06 12:02:14.932Z] [0003]     ExeSessionProcess.ProcessTitleEvent leaving
[2012-12-06 12:02:14.932Z] [0003]     ExeSessionProcess.ProcessInputEvent entering
[2012-12-06 12:02:14.932Z] [0003]       Scheduling output: [winscp> option batch on]
[2012-12-06 12:02:14.932Z] [0003]     ExeSessionProcess.ProcessInputEvent leaving
[2012-12-06 12:02:14.932Z] [0003]     Scheduling output: [batch           on        ]
[2012-12-06 12:02:14.932Z] [0003]       Scheduling output: [winscp> option confirm off]
[2012-12-06 12:02:14.932Z] [0003]     Scheduling output: [confirm         off       ]
[2012-12-06 12:02:14.932Z] [0003]       Scheduling output: [winscp> option reconnecttime 120]
[2012-12-06 12:02:14.932Z] [0003]     Scheduling output: [reconnecttime   120       ]
[2012-12-06 12:02:14.932Z] [0003]       Scheduling output: [winscp> open -passive=1 -timeout=120 "ftp://ftser@tag.gotdns.com:121"]
[2012-12-06 12:02:14.964Z] [0003]   ExeSessionProcess.ProcessEvent entering
[2012-12-06 12:02:15.010Z] [0003]     Scheduling output: [Connecting to tag.gotdns.com:121 ...]
[2012-12-06 12:02:15.010Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-12-06 12:02:15.088Z] [0001]   SessionLogReader.Read entering
[2012-12-06 12:02:15.088Z] [0001]     Opening log
[2012-12-06 12:02:15.088Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:15.088Z] [0001]     Skipping 0 elements
[2012-12-06 12:02:15.088Z] [0001]     Error logging log contents
[2012-12-06 12:02:15.088Z] [0001]   SessionLogReader.Read leaving
[2012-12-06 12:02:15.120Z] [0001]     Waiting for log update and dispatching events for 125
[2012-12-06 12:02:15.120Z] [0001]     Output: [winscp> option batch on]
[2012-12-06 12:02:15.120Z] [0001]     Output: [batch           on        ]
[2012-12-06 12:02:15.120Z] [0001]     Output: [winscp> option confirm off]
[2012-12-06 12:02:15.120Z] [0001]     Output: [confirm         off       ]
[2012-12-06 12:02:15.120Z] [0001]     Output: [winscp> option reconnecttime 120]
[2012-12-06 12:02:15.120Z] [0001]     Output: [reconnecttime   120       ]
[2012-12-06 12:02:15.120Z] [0001]     Output: [winscp> open -passive=1 -timeout=120 "ftp://ftser@tag.gotdns.com:121"]
[2012-12-06 12:02:15.120Z] [0001]     Output: [Connecting to tag.gotdns.com:121 ...]
[2012-12-06 12:02:15.260Z] [0001]     Opening log
[2012-12-06 12:02:15.260Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:15.260Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:15.260Z] [0001]     Waiting for log update and dispatching events for 250
[2012-12-06 12:02:15.369Z] [0003]   ExeSessionProcess.ProcessEvent entering
[2012-12-06 12:02:15.369Z] [0003]     Scheduling output: [Connected with tag.gotdns.com:121. Waiting for welcome message...]
[2012-12-06 12:02:15.369Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-12-06 12:02:15.369Z] [0001]     Output: [Connected with tag.gotdns.com:121. Waiting for welcome message...]
[2012-12-06 12:02:15.525Z] [0001]     Opening log
[2012-12-06 12:02:15.525Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:15.525Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:15.525Z] [0001]     Waiting for log update and dispatching events for 500
[2012-12-06 12:02:16.040Z] [0001]     Opening log
[2012-12-06 12:02:16.040Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:16.040Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:16.040Z] [0001]     Waiting for log update and dispatching events for 1000
[2012-12-06 12:02:17.054Z] [0001]     Opening log
[2012-12-06 12:02:17.054Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:17.054Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:17.054Z] [0001]     Waiting for log update and dispatching events for 1000
[2012-12-06 12:02:18.068Z] [0001]     Opening log
[2012-12-06 12:02:18.068Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:18.068Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:18.068Z] [0001]     Waiting for log update and dispatching events for 1000
[2012-12-06 12:02:19.082Z] [0001]     Opening log
[2012-12-06 12:02:19.082Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:19.082Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:19.082Z] [0001]     Waiting for log update and dispatching events for 1000
[2012-12-06 12:02:20.096Z] [0001]     Opening log
[2012-12-06 12:02:20.096Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:20.096Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:20.096Z] [0001]     Waiting for log update and dispatching events for 1000
[2012-12-06 12:02:21.110Z] [0001]     Opening log
[2012-12-06 12:02:21.110Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:21.110Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:21.110Z] [0001]     Waiting for log update and dispatching events for 1000
[2012-12-06 12:02:22.124Z] [0001]     Opening log
[2012-12-06 12:02:22.124Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:22.124Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:22.124Z] [0001]     Waiting for log update and dispatching events for 1000
[2012-12-06 12:02:23.138Z] [0001]     Opening log
[2012-12-06 12:02:23.138Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:23.138Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:23.138Z] [0001]     Waiting for log update and dispatching events for 1000
[2012-12-06 12:02:24.152Z] [0001]     Opening log
[2012-12-06 12:02:24.152Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:24.152Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:24.152Z] [0001]     Waiting for log update and dispatching events for 1000
[2012-12-06 12:02:24.417Z] [0003]   ExeSessionProcess.ProcessEvent entering
[2012-12-06 12:02:24.417Z] [0003]     Scheduling output: [Connected]
[2012-12-06 12:02:24.417Z] [0001]     Output: [Connected]
[2012-12-06 12:02:24.417Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-12-06 12:02:24.417Z] [0003]     Scheduling output: [Starting the session...]
[2012-12-06 12:02:24.417Z] [0001]     Output: [Starting the session...]
[2012-12-06 12:02:24.745Z] [0003]   ExeSessionProcess.ProcessEvent entering
[2012-12-06 12:02:24.745Z] [0003]     Scheduling output: [Reading remote directory...]
[2012-12-06 12:02:24.745Z] [0001]     Output: [Reading remote directory...]
[2012-12-06 12:02:24.745Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-12-06 12:02:24.745Z] [0003]     Scheduling output: [Session started.]
[2012-12-06 12:02:24.745Z] [0001]     Output: [Session started.]
[2012-12-06 12:02:24.745Z] [0003]     Scheduling output: [Active session: [1] ftser@tag.gotdns.com]
[2012-12-06 12:02:24.745Z] [0001]     Output: [Active session: [1] ftser@tag.gotdns.com]
[2012-12-06 12:02:24.745Z] [0003]     ExeSessionProcess.ProcessTitleEvent entering
[2012-12-06 12:02:24.745Z] [0003]       Not-supported title event [ftser@tag.gotdns.com - WinSCP]
[2012-12-06 12:02:24.745Z] [0003]     ExeSessionProcess.ProcessTitleEvent leaving
[2012-12-06 12:02:24.745Z] [0003]     ExeSessionProcess.ProcessInputEvent entering
[2012-12-06 12:02:25.166Z] [0001]     Opening log
[2012-12-06 12:02:25.166Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:25.166Z] [0001]     Skipping 4 elements
[2012-12-06 12:02:25.166Z] [0001]     Error logging log contents
[2012-12-06 12:02:25.166Z] [0001]   SessionLogReader.Read leaving
[2012-12-06 12:02:25.166Z] [0001]   SessionLogReader.Read entering
[2012-12-06 12:02:25.166Z] [0001]   ElementLogReader.Dispose entering
[2012-12-06 12:02:25.166Z] [0001]     ElementLogReader.ReadToEnd entering
[2012-12-06 12:02:25.166Z] [0001]     ElementLogReader.ReadToEnd leaving
[2012-12-06 12:02:25.166Z] [0001]   ElementLogReader.Dispose leaving
[2012-12-06 12:02:25.166Z] [0001] CallstackAndLock..ctor leaving
[2012-12-06 12:02:25.182Z] [0001] CallstackAndLock..ctor entering
[2012-12-06 12:02:25.182Z] [0001]   Command: [put  -nopermissions -preservetime -transfer="binary" -- "C:\\wamp\\www\\source\\cam1\006E060214F1(Cam 124)_0_20121206120126_43998.jpg" "/cam1/"]
[2012-12-06 12:02:25.182Z] [0001]   ExeSessionProcess.ExecuteCommand entering
[2012-12-06 12:02:25.182Z] [0001]   ExeSessionProcess.ExecuteCommand leaving
[2012-12-06 12:02:25.182Z] [0003]       Scheduling output: [winscp> put  -nopermissions -preservetime -transfer="binary" -- "C:\\wamp\\www\\source\\cam1\006E060214F1(Cam 124)_0_20121206120126_43998.jpg" "/cam1/"]
[2012-12-06 12:02:25.182Z] [0003]     ExeSessionProcess.ProcessInputEvent leaving
[2012-12-06 12:02:25.182Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-12-06 12:02:25.182Z] [0001]   SessionLogReader.Read entering
[2012-12-06 12:02:25.182Z] [0001]     Error logging log contents
[2012-12-06 12:02:25.182Z] [0001]   SessionLogReader.Read leaving
[2012-12-06 12:02:25.182Z] [0001]     Waiting for log update and dispatching events for 125
[2012-12-06 12:02:25.182Z] [0001]     Output: [winscp> put  -nopermissions -preservetime -transfer="binary" -- "C:\\wamp\\www\\source\\cam1\006E060214F1(Cam 124)_0_20121206120126_43998.jpg" "/cam1/"]
[2012-12-06 12:02:25.197Z] [0003]   ExeSessionProcess.ProcessEvent entering
[2012-12-06 12:02:25.197Z] [0003]     Buffered from-beginning message [C:\\wamp\\www\\source\\cam1\006E060214F1(Cam 124)_0_20121206120126_43998.jpg |          0 KiB |    0.0 KiB/s | binary |   0%]
[2012-12-06 12:02:25.197Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-12-06 12:02:25.322Z] [0001]     Opening log
[2012-12-06 12:02:25.322Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:25.322Z] [0001]     Skipping 10 elements
[2012-12-06 12:02:25.322Z] [0001]     Waiting for log update and dispatching events for 250
[2012-12-06 12:02:25.587Z] [0001]     Opening log
[2012-12-06 12:02:25.587Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:25.587Z] [0001]     Skipping 10 elements
[2012-12-06 12:02:25.587Z] [0001]     Waiting for log update and dispatching events for 500
[2012-12-06 12:02:26.102Z] [0001]     Opening log
[2012-12-06 12:02:26.102Z] [0001]     Log opened with write sharing
[2012-12-06 12:02:26.102Z] [0001]     Skipping 10 elements
[2012-12-06 12:02:26.102Z] [0001]     Waiting for log update and dispatching events for 1000
[/quote]
Unfortunatelly that is not possible atm.
