Topic "WinSCP.exe*32 Processes in task manager"
sameer.softyhcl
I am using WinSCP.dll (File Version: 1.0.1.869, Product Version:5.0.9.0) in C# for downloading files from SFTP server. My application is a windows service which keep on downloading files from FTP server. The application works for 2-3 hours, then the Windows Service stops automatically.
To make the issue worst, the WinSCP.exe*32 Process remains as it is in Task Manager though the my Windows Service stopped. So everytime I manually start my service, the previous WinSCP.exe*32 process remains as it is.
If I do this 12-13 times in a day, I found my task manager is piled up with 12/13 WinSCP.exe*32 processes and if the count goes upto 30-40, WinSCP stops connecting to the FTP Server completely.
Please suggest some solution.
What does it mean "Windows Service stops automatically"? Is it stopped grafully or does it crash? Is Session.Dispose called? What is your version of Windows?
pmsw
Got the same problem. My windows version is windows server 2008r2. Have tried different versions of wincsp. For every time wincsp is executed a process is started in the tastkmanager but not stopped or killed. Finally the service doesn't work anymore at all. immediately after the processes are killed manually the windows service work as normal.
pmsw
I've sent you a mail!
