check if file exists at the remote path using wild card
VKDD
United States
I was able to use session.FileExists using a specific file name in the remote path (/test/abc.zip), but, when I changed the file name to a wild card (/test/*.zip) it gives fileExists = false, even though a zip file exists in the folder.
How can I use wild card to see if file exists in that folder. Based on that I want to redirect the flow of my application.
Thanks.
Re: check if file exists at the remote path using wild card
Session.FileExists accepts only full path to a single file/directory, no masks.
