Topic "Invalid access to memory"
GregM
When transferring a file from the local computer to the remote computer by using the button "F5 Copy", the file transfer failed part-way through and the following error message was displayed: "Invalid access to memory".
On following the link to the Help page [http://winscp.net/eng/docs/message_invalid_access_to_memory], the information therein states: "This error message is not useful for you as an end-user. It generally means that there is a bug in the software. Please report the bug."
The issue occurred repeatedly using "F5 Copy". However when the file was transferred via Drag&Drop, there was no issue.
OS: Windows 7 Enterprise 32-bit
WinSCP: 5.1.1 (Build 2735)
GUI: Commander
Transfer protocol: SFTP
Please upgrade to the latest version and report if it fixed the problem or not. Thanks.
GregM
Hi, upgrading to the latest version has resolved this issue.
Thank you.
Greg.
