Topic "What is host key and how can i get that"
ykmohank
I have to automate a task of sftp few files using winscp.
While looking at the command syntax it was mentioned that i need to have host key to achieve this.
Can someone please help me on how can i get this one.
geraldb
Try to connect server using WinSCP.exe as graphical interface with SFTP-protocol and port 22. You don't have to use correct login data and after this scan generated log file. This contains a line like
Host key fingerprint is:
and the following line contains host key, e.g.
ssh-dss 1024 12:34:56:78:90:ab:cd:ef:12:34:56:78:90:ab:cd:ef
The host key are 16 blocks separated by : in example before
ykmohank
Thanks for you reply,But can you please guide me about the location where i can see the generated log file.
And once i got the host key what i need to do to automate my task of sending files to the targeted server.
Please help me i am very new to WinSCP and SFTP.
geraldb
Standard is path of used .exe file.
You have to generate a script and call this...
read help http://winscp.net/eng/docs/scripting
and examples http://winscp.net/eng/docs/scripting#example
best wishes
Gerald
Please read FAQ:
https://winscp.net/eng/docs/faq_hostkey
