Topic "Can't Access Root Directory"
David Mont
I just installed WinSCP on the recommendation of a colleague. I was able to log into my NAS storage device running BusyBox Linux.
I was able to see the entire directory structure from the root up.
I logged off and later re-logged into the system with the same credentials and all I can see now is my share file, the public and web directory. I see /root but can't get to any of the other directories /var /etc etc.
If I log in using bitvise same credentials and via the command line and do a cd / I get to the root level and can access everything from there.
Any help is appreciated as it would be great to be able to navigate without having to use command line and the vi editor!
WinSCP shot.PNG (21.92 KB)
Description: Screen shot of file directory
David Mont
If I choose the command option it opens another window and logs in with the same credentials. I can then do an ls / and see all the directories I can't access via the GUI. See screenshot attached
command line shot.PNG (93.82 KB) [Download]
Description: (none)
Please attach a full log file showing the problem (using the latest version of WinSCP) on Debug Level 1.
David M
I changed the protocol on the login screen from SFTP to SCP and it seems to be working fine. I am logging into a Synology Diskstation and I have enabled SFTP. The diskstation is running BusyBox linux. Attached are two log files one from an SCP session that lets me get to root files and one from an SFTP session that does not. I am able to log in using the SFTP protocol and the Admin account (log files not attached) This lets me get to the share files but not the root level. If I log in as Admin an use SCP I can also see the root files.
Davidm sftp.log (9.71 KB) [Download]
Description: Debug file from logging in using the SFTP protocol
Davidm SCP.log (110.49 KB) [Download]
Description: Debug file logging in as root user with SCP protocol
