Topic "hangs when accessing dir w/ many files"
wakalix
WinSCP often hangs when I try to access directories with a large number of files. Here are the details. Any suggestions would be greatly appreciated.
Brian
* Version of WinSCP: 5.1.3
* Version of Microsoft Windows: Windows 7 Professional
* Transfer protocol (SFTP, FTP or SCP). Both SFTP and SCP
* Mention if you use GUI or scripting/automation. GUI, Explorer
* Error message.
Quote:
Host is not communicating for more than 15 seconds. Still waiting ...
Note: If problem repeats, try turning off 'Optimize connection buffer size.'
Warning: Aborting this operation will close connection!
See also the log file, attached.
* Precise steps that lead to the problem:
This happens when I try to access a directory containing many files. In the case above, there are 338 files in the directory I'm trying to access.
* Software of the server you are connecting too (if you can get this information).
Linux hopper06 2.6.32.36-0.5-default #1 SMP 2011-04-14 10:12:31 +0200 x86_64 x86_64 x86_64 GNU/Linux
bts@hopper.nersc.gov-SFTP_hang.log (3.8 KB) [Download]
Description: Log file.
How long did you try to wait?
wakalix
The dialog box message that I quote above appears after 15 seconds. Or at least that what the text says the time out is. I can either abort or retry. If I retry, then either the 15-second time out happens again, or WinSCP becomes unresponsive.
Per Murphy's Law, the directory that has been giving me problems loads fine -- this morning. Both on SFTP and SCP. But I've had this problem for months, and finally decided to write in yesterday.
As I test, I made 10,000 empty files in a directory with a for loop & touch. Each file was empty. Both the SFTP and SCP connections took ~10 seconds to display the files. Or at leas the time-out dialog box did not appear. With SFTP, WinSCP was in a "not responding" state for ~2 seconds. But in any case, it works.
So maybe it's not merely the number of files, but the size of the files? The directories I have problems with about 100 80 MB files, and then many smaller files.
Brian
Thanks. Please let me know if you reproduce the problem.
vmatulis
Seems like if there is a loop like in case of /sys, search will not be done... ever.
Linux find itself works ok, is that a bug?
vmatulis
Not sure where would i find the logs.
Search simply continues, and it shows that it continues, that does not generate any errors. Only linix itself when it does search, i guess understands that it searched there, but winscp might not have that capability. That is i think there is a chance this scenario was not addressed.
If i excluse /sys and /proc file systems, where the loops are, then search is ok.
vmatulis
It would help to wake up first
File is huge, please mail me direct: vmatulis@gmail
-bash-4.1$ ll
total 0
-r--r--r-- 1 root root 4096 Dec 4 10:45 modalias
drwxr-xr-x 2 root root 0 Dec 4 10:45 power
lrwxrwxrwx 1 root root 0 Dec 4 10:45 subsystem -> ../../../bus/platform ****** Indicated a loop
-rw-r--r-- 1 root root 4096 Dec 4 10:45 uevent
2013-12-04 10:39:03.899 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/i8042/serio1/input/input3/device/input/input3/power".
> 2013-12-04 10:39:03.899 Type: SSH_FXP_OPENDIR, Size: 557, Number: 22213131
< 2013-12-04 10:39:03.899 Type: SSH_FXP_STATUS, Size: 24, Number: 22212868
. 2013-12-04 10:39:03.899 Discarding reserved response
< 2013-12-04 10:39:03.899 Type: SSH_FXP_HANDLE, Size: 13, Number: 22213131
> 2013-12-04 10:39:03.899 Type: SSH_FXP_READDIR, Size: 13, Number: 22213388
< 2013-12-04 10:39:03.904 Type: SSH_FXP_NAME, Size: 315, Number: 22213388
> 2013-12-04 10:39:03.904 Type: SSH_FXP_READDIR, Size: 13, Number: 22213644
< 2013-12-04 10:39:03.904 Type: SSH_FXP_STATUS, Size: 28, Number: 22213644
< 2013-12-04 10:39:03.904 Status code: 1
> 2013-12-04 10:39:03.904 Type: SSH_FXP_CLOSE, Size: 13, Number: 22213892
. 2013-12-04 10:39:03.904 .;d;0;2013-12-04T16:37:13.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:39:03.904 ..;d;0;2013-12-04T16:37:13.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:39:03.904 wakeup;-;4096;2013-12-04T16:37:13.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2013-12-04 10:39:03.904 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/i8042/serio1/input/input3/device/input/input3/mouse1".
> 2013-12-04 10:39:03.904 Type: SSH_FXP_OPENDIR, Size: 558, Number: 22214155
< 2013-12-04 10:39:03.909 Type: SSH_FXP_STATUS, Size: 24, Number: 22213892
. 2013-12-04 10:39:03.909 Discarding reserved response
< 2013-12-04 10:39:03.909 Type: SSH_FXP_HANDLE, Size: 13, Number: 22214155
> 2013-12-04 10:39:03.909 Type: SSH_FXP_READDIR, Size: 13, Number: 22214412
< 2013-12-04 10:39:03.914 Type: SSH_FXP_NAME, Size: 745, Number: 22214412
> 2013-12-04 10:39:03.914 Type: SSH_FXP_READDIR, Size: 13, Number: 22214668
. 2013-12-04 10:39:03.914 Reading symlink "subsystem".
> 2013-12-04 10:39:03.914 Type: SSH_FXP_READLINK, Size: 568, Number: 22214931
> 2013-12-04 10:39:03.914 Type: SSH_FXP_STAT, Size: 568, Number: 22215185
< 2013-12-04 10:39:03.914 Type: SSH_FXP_STATUS, Size: 28, Number: 22214668
. 2013-12-04 10:39:03.914 Storing reserved response
< 2013-12-04 10:39:03.919 Type: SSH_FXP_NAME, Size: 85, Number: 22214931
< 2013-12-04 10:39:03.919 Type: SSH_FXP_ATTRS, Size: 37, Number: 22215185
. 2013-12-04 10:39:03.919 Reading symlink "device".
> 2013-12-04 10:39:03.919 Type: SSH_FXP_READLINK, Size: 565, Number: 22215443
> 2013-12-04 10:39:03.919 Type: SSH_FXP_STAT, Size: 565, Number: 22215697
< 2013-12-04 10:39:03.959 Type: SSH_FXP_NAME, Size: 45, Number: 22215443
< 2013-12-04 10:39:03.959 Type: SSH_FXP_ATTRS, Size: 37, Number: 22215697
< 2013-12-04 10:39:03.964 Status code: 1
> 2013-12-04 10:39:03.964 Type: SSH_FXP_CLOSE, Size: 13, Number: 22215940
. 2013-12-04 10:39:03.964 .;d;0;2013-12-04T16:37:13.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:39:03.964 ..;d;0;2013-12-04T16:37:13.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:39:03.964 uevent;-;4096;2013-12-04T16:37:13.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2013-12-04 10:39:03.964 dev;-;4096;2013-12-04T16:37:13.000Z;"root" [0];"root" [0];r--r--r--;0
. 2013-12-04 10:39:03.964 subsystem;D;0;2013-12-04T16:37:13.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:39:03.964 device;D;0;2013-12-04T16:37:13.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:39:03.964 power;d;0;2013-12-04T16:37:13.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:39:03.964 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/i8042/serio1/input/input3/device/input/input3/mouse1/subsystem".
> 2013-12-04 10:39:03.964 Type: SSH_FXP_OPENDIR, Size: 568, Number: 22216203
< 2013-12-04 10:39:03.964 Type: SSH_FXP_STATUS, Size: 24, Number: 22215940
. 2013-12-04 10:39:03.964 Discarding reserved response
< 2013-12-04 10:39:03.964 Type: SSH_FXP_HANDLE, Size: 13, Number: 22216203
> 2013-12-04 10:39:03.964 Type: SSH_FXP_READDIR, Size: 13, Number: 22216460
< 2013-12-04 10:39:03.969 Type: SSH_FXP_NAME, Size: 1715, Number: 22216460
> 2013-12-04 10:39:03.969 Type: SSH_FXP_READDIR, Size: 13, Number: 22216716
. 2013-12-04 10:39:03.969 Reading symlink "input0".
> 2013-12-04 10:39:03.969 Type: SSH_FXP_READLINK, Size: 575, Number: 22216979
> 2013-12-04 10:39:03.969 Type: SSH_FXP_STAT, Size: 575, Number: 22217233
< 2013-12-04 10:39:03.974 Type: SSH_FXP_STATUS, Size: 28, Number: 22216716
. 2013-12-04 10:39:03.974 Storing reserved response
< 2013-12-04 10:39:03.974 Type: SSH_FXP_NAME, Size: 121, Number: 22216979
< 2013-12-04 10:39:03.974 Type: SSH_FXP_STATUS, Size: 29, Number: 22217233
< 2013-12-04 10:39:03.974 Status code: 2, Message: 22217233, Server: No such file, Language:
* 2013-12-04 10:39:03.974 (ECommand) Error reading symlink 'input0'.
* 2013-12-04 10:39:03.974 No such file or directory.
* 2013-12-04 10:39:03.974 Error code: 2
* 2013-12-04 10:39:03.974 Error message from server: No such file
* 2013-12-04 10:39:03.974 Request code: 17 Very Happy Very Happy
vmatulis
2013-12-04 10:37:11.404 Listing directory "/sys/devices/platform/pcspkr/subsystem".
> 2013-12-04 10:37:11.404 Type: SSH_FXP_OPENDIR, Size: 47, Number: 18880523
< 2013-12-04 10:37:11.404 Type: SSH_FXP_STATUS, Size: 24, Number: 18880260
. 2013-12-04 10:37:11.404 Discarding reserved response
< 2013-12-04 10:37:11.409 Type: SSH_FXP_HANDLE, Size: 13, Number: 18880523
> 2013-12-04 10:37:11.409 Type: SSH_FXP_READDIR, Size: 13, Number: 18880780
< 2013-12-04 10:37:11.409 Type: SSH_FXP_NAME, Size: 787, Number: 18880780
> 2013-12-04 10:37:11.409 Type: SSH_FXP_READDIR, Size: 13, Number: 18881036
< 2013-12-04 10:37:11.414 Type: SSH_FXP_STATUS, Size: 28, Number: 18881036
< 2013-12-04 10:37:11.414 Status code: 1
> 2013-12-04 10:37:11.414 Type: SSH_FXP_CLOSE, Size: 13, Number: 18881284
. 2013-12-04 10:37:11.414 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.414 ..;d;0;2013-12-02T22:01:02.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.414 uevent;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];-w-------;0
. 2013-12-04 10:37:11.414 devices;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.414 drivers;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.414 drivers_probe;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];-w-------;0
. 2013-12-04 10:37:11.414 drivers_autoprobe;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2013-12-04 10:37:11.414 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices".
> 2013-12-04 10:37:11.414 Type: SSH_FXP_OPENDIR, Size: 55, Number: 18881547
< 2013-12-04 10:37:11.414 Type: SSH_FXP_STATUS, Size: 24, Number: 18881284
. 2013-12-04 10:37:11.414 Discarding reserved response
< 2013-12-04 10:37:11.414 Type: SSH_FXP_HANDLE, Size: 13, Number: 18881547
> 2013-12-04 10:37:11.414 Type: SSH_FXP_READDIR, Size: 13, Number: 18881804
< 2013-12-04 10:37:11.419 Type: SSH_FXP_NAME, Size: 891, Number: 18881804
> 2013-12-04 10:37:11.419 Type: SSH_FXP_READDIR, Size: 13, Number: 18882060
. 2013-12-04 10:37:11.419 Reading symlink "pcspkr".
> 2013-12-04 10:37:11.419 Type: SSH_FXP_READLINK, Size: 62, Number: 18882323
> 2013-12-04 10:37:11.419 Type: SSH_FXP_STAT, Size: 62, Number: 18882577
< 2013-12-04 10:37:11.419 Type: SSH_FXP_STATUS, Size: 28, Number: 18882060
. 2013-12-04 10:37:11.419 Storing reserved response
< 2013-12-04 10:37:11.424 Type: SSH_FXP_NAME, Size: 85, Number: 18882323
< 2013-12-04 10:37:11.424 Type: SSH_FXP_ATTRS, Size: 37, Number: 18882577
. 2013-12-04 10:37:11.424 Reading symlink "vesafb.0".
> 2013-12-04 10:37:11.424 Type: SSH_FXP_READLINK, Size: 64, Number: 18882835
> 2013-12-04 10:37:11.424 Type: SSH_FXP_STAT, Size: 64, Number: 18883089
< 2013-12-04 10:37:11.424 Type: SSH_FXP_NAME, Size: 89, Number: 18882835
< 2013-12-04 10:37:11.424 Type: SSH_FXP_ATTRS, Size: 37, Number: 18883089
. 2013-12-04 10:37:11.429 Reading symlink "serial8250".
> 2013-12-04 10:37:11.429 Type: SSH_FXP_READLINK, Size: 66, Number: 18883347
> 2013-12-04 10:37:11.429 Type: SSH_FXP_STAT, Size: 66, Number: 18883601
< 2013-12-04 10:37:11.429 Type: SSH_FXP_NAME, Size: 93, Number: 18883347
< 2013-12-04 10:37:11.429 Type: SSH_FXP_ATTRS, Size: 37, Number: 18883601
. 2013-12-04 10:37:11.429 Reading symlink "Fixed MDIO bus.0".
> 2013-12-04 10:37:11.429 Type: SSH_FXP_READLINK, Size: 72, Number: 18883859
> 2013-12-04 10:37:11.429 Type: SSH_FXP_STAT, Size: 72, Number: 18884113
< 2013-12-04 10:37:11.434 Type: SSH_FXP_NAME, Size: 105, Number: 18883859
< 2013-12-04 10:37:11.434 Type: SSH_FXP_ATTRS, Size: 37, Number: 18884113
. 2013-12-04 10:37:11.434 Reading symlink "i8042".
> 2013-12-04 10:37:11.434 Type: SSH_FXP_READLINK, Size: 61, Number: 18884371
> 2013-12-04 10:37:11.434 Type: SSH_FXP_STAT, Size: 61, Number: 18884625
< 2013-12-04 10:37:11.434 Type: SSH_FXP_NAME, Size: 83, Number: 18884371
< 2013-12-04 10:37:11.439 Type: SSH_FXP_ATTRS, Size: 37, Number: 18884625
. 2013-12-04 10:37:11.439 Reading symlink "microcode".
> 2013-12-04 10:37:11.439 Type: SSH_FXP_READLINK, Size: 65, Number: 18884883
> 2013-12-04 10:37:11.439 Type: SSH_FXP_STAT, Size: 65, Number: 18885137
< 2013-12-04 10:37:11.439 Type: SSH_FXP_NAME, Size: 91, Number: 18884883
< 2013-12-04 10:37:11.444 Type: SSH_FXP_ATTRS, Size: 37, Number: 18885137
< 2013-12-04 10:37:11.444 Status code: 1
> 2013-12-04 10:37:11.444 Type: SSH_FXP_CLOSE, Size: 13, Number: 18885380
. 2013-12-04 10:37:11.444 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.444 ..;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.444 pcspkr;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.444 vesafb.0;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.444 serial8250;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.444 Fixed MDIO bus.0;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.444 i8042;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.444 microcode;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.444 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr".
> 2013-12-04 10:37:11.444 Type: SSH_FXP_OPENDIR, Size: 62, Number: 18885643
< 2013-12-04 10:37:11.444 Type: SSH_FXP_STATUS, Size: 24, Number: 18885380
. 2013-12-04 10:37:11.444 Discarding reserved response
< 2013-12-04 10:37:11.449 Type: SSH_FXP_HANDLE, Size: 13, Number: 18885643
> 2013-12-04 10:37:11.449 Type: SSH_FXP_READDIR, Size: 13, Number: 18885900
< 2013-12-04 10:37:11.454 Type: SSH_FXP_NAME, Size: 647, Number: 18885900
> 2013-12-04 10:37:11.454 Type: SSH_FXP_READDIR, Size: 13, Number: 18886156
. 2013-12-04 10:37:11.454 Reading symlink "subsystem".
> 2013-12-04 10:37:11.454 Type: SSH_FXP_READLINK, Size: 72, Number: 18886419
> 2013-12-04 10:37:11.454 Type: SSH_FXP_STAT, Size: 72, Number: 18886673
< 2013-12-04 10:37:11.454 Type: SSH_FXP_STATUS, Size: 28, Number: 18886156
. 2013-12-04 10:37:11.454 Storing reserved response
< 2013-12-04 10:37:11.454 Type: SSH_FXP_NAME, Size: 63, Number: 18886419
< 2013-12-04 10:37:11.454 Type: SSH_FXP_ATTRS, Size: 37, Number: 18886673
< 2013-12-04 10:37:11.454 Status code: 1
> 2013-12-04 10:37:11.454 Type: SSH_FXP_CLOSE, Size: 13, Number: 18886916
. 2013-12-04 10:37:11.454 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.454 ..;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.454 uevent;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2013-12-04 10:37:11.454 modalias;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];r--r--r--;0
. 2013-12-04 10:37:11.454 subsystem;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.454 power;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.459 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem".
> 2013-12-04 10:37:11.459 Type: SSH_FXP_OPENDIR, Size: 72, Number: 18887179
< 2013-12-04 10:37:11.459 Type: SSH_FXP_STATUS, Size: 24, Number: 18886916
. 2013-12-04 10:37:11.459 Discarding reserved response
< 2013-12-04 10:37:11.459 Type: SSH_FXP_HANDLE, Size: 13, Number: 18887179
> 2013-12-04 10:37:11.459 Type: SSH_FXP_READDIR, Size: 13, Number: 18887436
< 2013-12-04 10:37:11.459 Type: SSH_FXP_NAME, Size: 787, Number: 18887436
> 2013-12-04 10:37:11.459 Type: SSH_FXP_READDIR, Size: 13, Number: 18887692
< 2013-12-04 10:37:11.464 Type: SSH_FXP_STATUS, Size: 28, Number: 18887692
< 2013-12-04 10:37:11.464 Status code: 1
> 2013-12-04 10:37:11.464 Type: SSH_FXP_CLOSE, Size: 13, Number: 18887940
. 2013-12-04 10:37:11.464 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.464 ..;d;0;2013-12-02T22:01:02.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.464 uevent;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];-w-------;0
. 2013-12-04 10:37:11.464 devices;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.464 drivers;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.464 drivers_probe;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];-w-------;0
. 2013-12-04 10:37:11.464 drivers_autoprobe;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2013-12-04 10:37:11.464 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices".
> 2013-12-04 10:37:11.464 Type: SSH_FXP_OPENDIR, Size: 80, Number: 18888203
< 2013-12-04 10:37:11.464 Type: SSH_FXP_STATUS, Size: 24, Number: 18887940
. 2013-12-04 10:37:11.464 Discarding reserved response
< 2013-12-04 10:37:11.469 Type: SSH_FXP_HANDLE, Size: 13, Number: 18888203
> 2013-12-04 10:37:11.469 Type: SSH_FXP_READDIR, Size: 13, Number: 18888460
< 2013-12-04 10:37:11.469 Type: SSH_FXP_NAME, Size: 891, Number: 18888460
> 2013-12-04 10:37:11.469 Type: SSH_FXP_READDIR, Size: 13, Number: 18888716
. 2013-12-04 10:37:11.469 Reading symlink "pcspkr".
> 2013-12-04 10:37:11.469 Type: SSH_FXP_READLINK, Size: 87, Number: 18888979
> 2013-12-04 10:37:11.469 Type: SSH_FXP_STAT, Size: 87, Number: 18889233
< 2013-12-04 10:37:11.474 Type: SSH_FXP_STATUS, Size: 28, Number: 18888716
. 2013-12-04 10:37:11.474 Storing reserved response
< 2013-12-04 10:37:11.474 Type: SSH_FXP_NAME, Size: 85, Number: 18888979
< 2013-12-04 10:37:11.474 Type: SSH_FXP_ATTRS, Size: 37, Number: 18889233
. 2013-12-04 10:37:11.474 Reading symlink "vesafb.0".
> 2013-12-04 10:37:11.474 Type: SSH_FXP_READLINK, Size: 89, Number: 18889491
> 2013-12-04 10:37:11.474 Type: SSH_FXP_STAT, Size: 89, Number: 18889745
< 2013-12-04 10:37:11.474 Type: SSH_FXP_NAME, Size: 89, Number: 18889491
< 2013-12-04 10:37:11.479 Type: SSH_FXP_ATTRS, Size: 37, Number: 18889745
. 2013-12-04 10:37:11.479 Reading symlink "serial8250".
> 2013-12-04 10:37:11.479 Type: SSH_FXP_READLINK, Size: 91, Number: 18890003
> 2013-12-04 10:37:11.479 Type: SSH_FXP_STAT, Size: 91, Number: 18890257
< 2013-12-04 10:37:11.479 Type: SSH_FXP_NAME, Size: 93, Number: 18890003
< 2013-12-04 10:37:11.479 Type: SSH_FXP_ATTRS, Size: 37, Number: 18890257
. 2013-12-04 10:37:11.479 Reading symlink "Fixed MDIO bus.0".
> 2013-12-04 10:37:11.479 Type: SSH_FXP_READLINK, Size: 97, Number: 18890515
> 2013-12-04 10:37:11.479 Type: SSH_FXP_STAT, Size: 97, Number: 18890769
< 2013-12-04 10:37:11.484 Type: SSH_FXP_NAME, Size: 105, Number: 18890515
< 2013-12-04 10:37:11.484 Type: SSH_FXP_ATTRS, Size: 37, Number: 18890769
. 2013-12-04 10:37:11.484 Reading symlink "i8042".
> 2013-12-04 10:37:11.484 Type: SSH_FXP_READLINK, Size: 86, Number: 18891027
> 2013-12-04 10:37:11.484 Type: SSH_FXP_STAT, Size: 86, Number: 18891281
< 2013-12-04 10:37:11.484 Type: SSH_FXP_NAME, Size: 83, Number: 18891027
< 2013-12-04 10:37:11.484 Type: SSH_FXP_ATTRS, Size: 37, Number: 18891281
. 2013-12-04 10:37:11.484 Reading symlink "microcode".
> 2013-12-04 10:37:11.484 Type: SSH_FXP_READLINK, Size: 90, Number: 18891539
> 2013-12-04 10:37:11.484 Type: SSH_FXP_STAT, Size: 90, Number: 18891793
< 2013-12-04 10:37:11.489 Type: SSH_FXP_NAME, Size: 91, Number: 18891539
< 2013-12-04 10:37:11.489 Type: SSH_FXP_ATTRS, Size: 37, Number: 18891793
< 2013-12-04 10:37:11.489 Status code: 1
> 2013-12-04 10:37:11.489 Type: SSH_FXP_CLOSE, Size: 13, Number: 18892036
. 2013-12-04 10:37:11.489 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.489 ..;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.489 pcspkr;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.489 vesafb.0;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.489 serial8250;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.489 Fixed MDIO bus.0;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.489 i8042;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.489 microcode;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.489 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr".
> 2013-12-04 10:37:11.489 Type: SSH_FXP_OPENDIR, Size: 87, Number: 18892299
< 2013-12-04 10:37:11.489 Type: SSH_FXP_STATUS, Size: 24, Number: 18892036
. 2013-12-04 10:37:11.489 Discarding reserved response
< 2013-12-04 10:37:11.494 Type: SSH_FXP_HANDLE, Size: 13, Number: 18892299
> 2013-12-04 10:37:11.494 Type: SSH_FXP_READDIR, Size: 13, Number: 18892556
< 2013-12-04 10:37:11.494 Type: SSH_FXP_NAME, Size: 647, Number: 18892556
> 2013-12-04 10:37:11.494 Type: SSH_FXP_READDIR, Size: 13, Number: 18892812
. 2013-12-04 10:37:11.494 Reading symlink "subsystem".
> 2013-12-04 10:37:11.494 Type: SSH_FXP_READLINK, Size: 97, Number: 18893075
> 2013-12-04 10:37:11.494 Type: SSH_FXP_STAT, Size: 97, Number: 18893329
< 2013-12-04 10:37:11.494 Type: SSH_FXP_STATUS, Size: 28, Number: 18892812
. 2013-12-04 10:37:11.494 Storing reserved response
< 2013-12-04 10:37:11.499 Type: SSH_FXP_NAME, Size: 63, Number: 18893075
< 2013-12-04 10:37:11.499 Type: SSH_FXP_ATTRS, Size: 37, Number: 18893329
< 2013-12-04 10:37:11.499 Status code: 1
> 2013-12-04 10:37:11.499 Type: SSH_FXP_CLOSE, Size: 13, Number: 18893572
. 2013-12-04 10:37:11.499 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.499 ..;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.499 uevent;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2013-12-04 10:37:11.499 modalias;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];r--r--r--;0
. 2013-12-04 10:37:11.499 subsystem;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.499 power;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.499 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem".
> 2013-12-04 10:37:11.499 Type: SSH_FXP_OPENDIR, Size: 97, Number: 18893835
< 2013-12-04 10:37:11.499 Type: SSH_FXP_STATUS, Size: 24, Number: 18893572
. 2013-12-04 10:37:11.499 Discarding reserved response
< 2013-12-04 10:37:11.499 Type: SSH_FXP_HANDLE, Size: 13, Number: 18893835
> 2013-12-04 10:37:11.499 Type: SSH_FXP_READDIR, Size: 13, Number: 18894092
< 2013-12-04 10:37:11.504 Type: SSH_FXP_NAME, Size: 787, Number: 18894092
> 2013-12-04 10:37:11.504 Type: SSH_FXP_READDIR, Size: 13, Number: 18894348
< 2013-12-04 10:37:11.504 Type: SSH_FXP_STATUS, Size: 28, Number: 18894348
< 2013-12-04 10:37:11.504 Status code: 1
> 2013-12-04 10:37:11.504 Type: SSH_FXP_CLOSE, Size: 13, Number: 18894596
. 2013-12-04 10:37:11.504 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.504 ..;d;0;2013-12-02T22:01:02.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.504 uevent;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];-w-------;0
. 2013-12-04 10:37:11.504 devices;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.504 drivers;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.504 drivers_probe;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];-w-------;0
. 2013-12-04 10:37:11.504 drivers_autoprobe;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2013-12-04 10:37:11.504 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices".
> 2013-12-04 10:37:11.504 Type: SSH_FXP_OPENDIR, Size: 105, Number: 18894859
< 2013-12-04 10:37:11.504 Type: SSH_FXP_STATUS, Size: 24, Number: 18894596
. 2013-12-04 10:37:11.504 Discarding reserved response
< 2013-12-04 10:37:11.509 Type: SSH_FXP_HANDLE, Size: 13, Number: 18894859
> 2013-12-04 10:37:11.509 Type: SSH_FXP_READDIR, Size: 13, Number: 18895116
< 2013-12-04 10:37:11.509 Type: SSH_FXP_NAME, Size: 891, Number: 18895116
> 2013-12-04 10:37:11.509 Type: SSH_FXP_READDIR, Size: 13, Number: 18895372
. 2013-12-04 10:37:11.509 Reading symlink "pcspkr".
> 2013-12-04 10:37:11.509 Type: SSH_FXP_READLINK, Size: 112, Number: 18895635
> 2013-12-04 10:37:11.509 Type: SSH_FXP_STAT, Size: 112, Number: 18895889
< 2013-12-04 10:37:11.509 Type: SSH_FXP_STATUS, Size: 28, Number: 18895372
. 2013-12-04 10:37:11.509 Storing reserved response
< 2013-12-04 10:37:11.514 Type: SSH_FXP_NAME, Size: 85, Number: 18895635
< 2013-12-04 10:37:11.514 Type: SSH_FXP_ATTRS, Size: 37, Number: 18895889
. 2013-12-04 10:37:11.514 Reading symlink "vesafb.0".
> 2013-12-04 10:37:11.514 Type: SSH_FXP_READLINK, Size: 114, Number: 18896147
> 2013-12-04 10:37:11.514 Type: SSH_FXP_STAT, Size: 114, Number: 18896401
< 2013-12-04 10:37:11.514 Type: SSH_FXP_NAME, Size: 89, Number: 18896147
< 2013-12-04 10:37:11.514 Type: SSH_FXP_ATTRS, Size: 37, Number: 18896401
. 2013-12-04 10:37:11.514 Reading symlink "serial8250".
> 2013-12-04 10:37:11.514 Type: SSH_FXP_READLINK, Size: 116, Number: 18896659
> 2013-12-04 10:37:11.514 Type: SSH_FXP_STAT, Size: 116, Number: 18896913
< 2013-12-04 10:37:11.514 Type: SSH_FXP_NAME, Size: 93, Number: 18896659
< 2013-12-04 10:37:11.519 Type: SSH_FXP_ATTRS, Size: 37, Number: 18896913
. 2013-12-04 10:37:11.519 Reading symlink "Fixed MDIO bus.0".
> 2013-12-04 10:37:11.519 Type: SSH_FXP_READLINK, Size: 122, Number: 18897171
> 2013-12-04 10:37:11.519 Type: SSH_FXP_STAT, Size: 122, Number: 18897425
< 2013-12-04 10:37:11.519 Type: SSH_FXP_NAME, Size: 105, Number: 18897171
< 2013-12-04 10:37:11.519 Type: SSH_FXP_ATTRS, Size: 37, Number: 18897425
. 2013-12-04 10:37:11.519 Reading symlink "i8042".
> 2013-12-04 10:37:11.519 Type: SSH_FXP_READLINK, Size: 111, Number: 18897683
> 2013-12-04 10:37:11.519 Type: SSH_FXP_STAT, Size: 111, Number: 18897937
< 2013-12-04 10:37:11.524 Type: SSH_FXP_NAME, Size: 83, Number: 18897683
< 2013-12-04 10:37:11.524 Type: SSH_FXP_ATTRS, Size: 37, Number: 18897937
. 2013-12-04 10:37:11.524 Reading symlink "microcode".
> 2013-12-04 10:37:11.524 Type: SSH_FXP_READLINK, Size: 115, Number: 18898195
> 2013-12-04 10:37:11.524 Type: SSH_FXP_STAT, Size: 115, Number: 18898449
< 2013-12-04 10:37:11.524 Type: SSH_FXP_NAME, Size: 91, Number: 18898195
< 2013-12-04 10:37:11.529 Type: SSH_FXP_ATTRS, Size: 37, Number: 18898449
< 2013-12-04 10:37:11.529 Status code: 1
> 2013-12-04 10:37:11.529 Type: SSH_FXP_CLOSE, Size: 13, Number: 18898692
. 2013-12-04 10:37:11.529 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.529 ..;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.529 pcspkr;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.529 vesafb.0;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.529 serial8250;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.529 Fixed MDIO bus.0;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.529 i8042;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.529 microcode;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.529 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr".
> 2013-12-04 10:37:11.529 Type: SSH_FXP_OPENDIR, Size: 112, Number: 18898955
< 2013-12-04 10:37:11.529 Type: SSH_FXP_STATUS, Size: 24, Number: 18898692
. 2013-12-04 10:37:11.529 Discarding reserved response
< 2013-12-04 10:37:11.529 Type: SSH_FXP_HANDLE, Size: 13, Number: 18898955
> 2013-12-04 10:37:11.529 Type: SSH_FXP_READDIR, Size: 13, Number: 18899212
< 2013-12-04 10:37:11.534 Type: SSH_FXP_NAME, Size: 647, Number: 18899212
> 2013-12-04 10:37:11.534 Type: SSH_FXP_READDIR, Size: 13, Number: 18899468
. 2013-12-04 10:37:11.534 Reading symlink "subsystem".
> 2013-12-04 10:37:11.534 Type: SSH_FXP_READLINK, Size: 122, Number: 18899731
> 2013-12-04 10:37:11.534 Type: SSH_FXP_STAT, Size: 122, Number: 18899985
< 2013-12-04 10:37:11.534 Type: SSH_FXP_STATUS, Size: 28, Number: 18899468
. 2013-12-04 10:37:11.534 Storing reserved response
< 2013-12-04 10:37:11.534 Type: SSH_FXP_NAME, Size: 63, Number: 18899731
< 2013-12-04 10:37:11.534 Type: SSH_FXP_ATTRS, Size: 37, Number: 18899985
< 2013-12-04 10:37:11.534 Status code: 1
> 2013-12-04 10:37:11.534 Type: SSH_FXP_CLOSE, Size: 13, Number: 18900228
. 2013-12-04 10:37:11.534 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.534 ..;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.534 uevent;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2013-12-04 10:37:11.534 modalias;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];r--r--r--;0
. 2013-12-04 10:37:11.534 subsystem;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.534 power;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.539 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem".
> 2013-12-04 10:37:11.539 Type: SSH_FXP_OPENDIR, Size: 122, Number: 18900491
< 2013-12-04 10:37:11.539 Type: SSH_FXP_STATUS, Size: 24, Number: 18900228
. 2013-12-04 10:37:11.539 Discarding reserved response
< 2013-12-04 10:37:11.539 Type: SSH_FXP_HANDLE, Size: 13, Number: 18900491
> 2013-12-04 10:37:11.539 Type: SSH_FXP_READDIR, Size: 13, Number: 18900748
< 2013-12-04 10:37:11.539 Type: SSH_FXP_NAME, Size: 787, Number: 18900748
> 2013-12-04 10:37:11.539 Type: SSH_FXP_READDIR, Size: 13, Number: 18901004
< 2013-12-04 10:37:11.544 Type: SSH_FXP_STATUS, Size: 28, Number: 18901004
< 2013-12-04 10:37:11.544 Status code: 1
> 2013-12-04 10:37:11.544 Type: SSH_FXP_CLOSE, Size: 13, Number: 18901252
. 2013-12-04 10:37:11.544 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.544 ..;d;0;2013-12-02T22:01:02.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.544 uevent;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];-w-------;0
. 2013-12-04 10:37:11.544 devices;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.544 drivers;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.544 drivers_probe;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];-w-------;0
. 2013-12-04 10:37:11.544 drivers_autoprobe;-;4096;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rw-r--r--;0
. 2013-12-04 10:37:11.544 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices".
> 2013-12-04 10:37:11.544 Type: SSH_FXP_OPENDIR, Size: 130, Number: 18901515
< 2013-12-04 10:37:11.544 Type: SSH_FXP_STATUS, Size: 24, Number: 18901252
. 2013-12-04 10:37:11.544 Discarding reserved response
< 2013-12-04 10:37:11.544 Type: SSH_FXP_HANDLE, Size: 13, Number: 18901515
> 2013-12-04 10:37:11.544 Type: SSH_FXP_READDIR, Size: 13, Number: 18901772
< 2013-12-04 10:37:11.549 Type: SSH_FXP_NAME, Size: 891, Number: 18901772
> 2013-12-04 10:37:11.549 Type: SSH_FXP_READDIR, Size: 13, Number: 18902028
. 2013-12-04 10:37:11.549 Reading symlink "pcspkr".
> 2013-12-04 10:37:11.549 Type: SSH_FXP_READLINK, Size: 137, Number: 18902291
> 2013-12-04 10:37:11.549 Type: SSH_FXP_STAT, Size: 137, Number: 18902545
< 2013-12-04 10:37:11.549 Type: SSH_FXP_STATUS, Size: 28, Number: 18902028
. 2013-12-04 10:37:11.549 Storing reserved response
< 2013-12-04 10:37:11.554 Type: SSH_FXP_NAME, Size: 85, Number: 18902291
< 2013-12-04 10:37:11.554 Type: SSH_FXP_ATTRS, Size: 37, Number: 18902545
. 2013-12-04 10:37:11.554 Reading symlink "vesafb.0".
> 2013-12-04 10:37:11.554 Type: SSH_FXP_READLINK, Size: 139, Number: 18902803
> 2013-12-04 10:37:11.554 Type: SSH_FXP_STAT, Size: 139, Number: 18903057
< 2013-12-04 10:37:11.554 Type: SSH_FXP_NAME, Size: 89, Number: 18902803
< 2013-12-04 10:37:11.554 Type: SSH_FXP_ATTRS, Size: 37, Number: 18903057
. 2013-12-04 10:37:11.554 Reading symlink "serial8250".
> 2013-12-04 10:37:11.554 Type: SSH_FXP_READLINK, Size: 141, Number: 18903315
> 2013-12-04 10:37:11.554 Type: SSH_FXP_STAT, Size: 141, Number: 18903569
< 2013-12-04 10:37:11.559 Type: SSH_FXP_NAME, Size: 93, Number: 18903315
< 2013-12-04 10:37:11.559 Type: SSH_FXP_ATTRS, Size: 37, Number: 18903569
. 2013-12-04 10:37:11.559 Reading symlink "Fixed MDIO bus.0".
> 2013-12-04 10:37:11.559 Type: SSH_FXP_READLINK, Size: 147, Number: 18903827
> 2013-12-04 10:37:11.559 Type: SSH_FXP_STAT, Size: 147, Number: 18904081
< 2013-12-04 10:37:11.559 Type: SSH_FXP_NAME, Size: 105, Number: 18903827
< 2013-12-04 10:37:11.559 Type: SSH_FXP_ATTRS, Size: 37, Number: 18904081
. 2013-12-04 10:37:11.564 Reading symlink "i8042".
> 2013-12-04 10:37:11.564 Type: SSH_FXP_READLINK, Size: 136, Number: 18904339
> 2013-12-04 10:37:11.564 Type: SSH_FXP_STAT, Size: 136, Number: 18904593
< 2013-12-04 10:37:11.564 Type: SSH_FXP_NAME, Size: 83, Number: 18904339
< 2013-12-04 10:37:11.564 Type: SSH_FXP_ATTRS, Size: 37, Number: 18904593
. 2013-12-04 10:37:11.564 Reading symlink "microcode".
> 2013-12-04 10:37:11.564 Type: SSH_FXP_READLINK, Size: 140, Number: 18904851
> 2013-12-04 10:37:11.564 Type: SSH_FXP_STAT, Size: 140, Number: 18905105
< 2013-12-04 10:37:11.569 Type: SSH_FXP_NAME, Size: 91, Number: 18904851
< 2013-12-04 10:37:11.569 Type: SSH_FXP_ATTRS, Size: 37, Number: 18905105
< 2013-12-04 10:37:11.569 Status code: 1
> 2013-12-04 10:37:11.569 Type: SSH_FXP_CLOSE, Size: 13, Number: 18905348
. 2013-12-04 10:37:11.569 .;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;2
. 2013-12-04 10:37:11.569 ..;d;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxr-xr-x;0
. 2013-12-04 10:37:11.569 pcspkr;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.569 vesafb.0;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.569 serial8250;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.569 Fixed MDIO bus.0;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.569 i8042;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.569 microcode;D;0;2013-12-04T16:37:10.000Z;"root" [0];"root" [0];rwxrwxrwx;1
. 2013-12-04 10:37:11.569 Listing directory "/sys/devices/platform/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr/subsystem/devices/pcspkr".
> 2013-12-04 10:37:11.569 Type: SSH_FXP_OPENDIR, Size: 137, Number: 18905611
< 2013-12-04 10:37:11.569 Type: SSH_FXP_STATUS, Size: 24, Number: 18905348
. 2013-12-04 10:37:11.569 Discarding reserved response
< 2013-12-04 10:37:11.569 Type: SSH_FXP_HANDLE, Size: 13, Number: 18905611
> 2013-12-04 10:37:11.569 Type: SSH_FXP_READDIR, Size: 13, Number: 18905868
http://winscp.net/tracker/show_bug.cgi?id=1093
eAddict
I have the same issue but I know there aren't links - just files.
The root has nearly 2900 files, one dir below has 1400, another 4635.
(root@sapqas)# cd 010JOBLG/
(root@sapqas)# ls -1 | wc -l
2838
(root@sapqas)# cd 2012
1473
(root@sapqas)# cd ..
(root@sapqas)# cd 2013
4635
Suggestions or work-a rounds are welcome!
Version 5.1.7
Please start a new thread and attach a full log file showing the problem (using the latest version of WinSCP).
