Topic "Can I use multi-session to multi sftp servers simultaneously"
Hiro.A
Now I am trying to make my program to manipulate several sftp servers simultaneously. For the first step, I tried ListDirectory from 3 servers by using backgroundworker objects.
But it seemed not to work correctly.
So, I want to hear, if I can use .net assembly thread-safe or not , in order to know it was caused by my fault or not.
Regards,
You can use separate Session objects from different threads. Single Session instance guards itself from concurrent accesses.
Please attach logs showing the problem.
Hiro.A
Ok,
So I understood it was caused by my fault. I must look for what went wrong.
I will retry later.
If I found something, I will tell you.
Thanks anyway,
Hiro.A
Now I found this issue's point.
I tried 3 servers , for each servers' tunnel, they used the same local tunnel port (50000).
But I did not know how to specify local tunnel port, would you teach me ?
Regards,
Hiro.A
I tried "TunnelLocalPortNumber" by AddRawSettings and seemed to succeed.
Thanks!
