Topic "Filemask switch when using GET"
locksonline
OK, I have done a fair amount of searching and I am still stumped with time ticking on.
I have a windows .bat file which then runs a winscp.txt file with commands via the console.
The winscp.txt file runs a number of commands successfully and the command
get *.txt
works just fine.
However, the following does not:
get -filemask="*.txt"
I thought it maybe an issue with the quotes, so have tried with or without quotes and or double quotes, etc.
The error being returned in the windows command prompt when running the .bat file is,
Quote:
Missing parameter for command 'get'
Any help or guidance greatly appreciated.
PS. WinSCP is version 5.1.2
You want to do either:
get -filemask="*.txt" *
(copies all *.txt files recursively)
get *.txt
(copies all *.txt file non-recursively)
locksonline
get *.txt
Many thanks for your reply, I have it working now.
thardon
I tried the same as 'locksonline'. Ok, I've changed txt to csv and I'm downloading to Windows temp file but I think that's not the problem.
GET -filemask="*.csv" * D:\temp\
Result of this codeline is that winscp copies many, many empty folders from remote to local. Am I doing anything wrong?
WINSCP is version 5.1.3
locksonline
I think I managed to get this working with the following line:
get -filemask="yourString"* *.txt
HTH
thardon
Thanks for your help! Smile
Unfortunately it doesn't work for me. Sad Now, It's copying no files at all.
The csv-Files are stored in sub-folders. Maybe that's why this one copies no files. WINSCP has to search recursively through all sub-folders. And it seems you have to use * as remote path..
Ok, so you want WinSCP to skip subfolders that contain no .csv files, right? WinSCP cannot do this.
