Topic "How to automatically answer the overwrite message"
lewis@pepperit.com
I'm trying to set up an ftp program and i have it working and copying files, however its always prompts to overwrite. What i want is when this screen prompts a bit of code to automatically say no to all overwrites. Hopefully that makes sense my code is below:
option batch abort
option batch off
open serverbackup
put c:\test\*.* /lewis/test/*.* -preservetime
close serverbackup
this is the first part of the script saved in a tmp file.
@echo on
rem WinSCP Server Automated Backup.
rem Created for Quantact.com
rem Settings.
rem Server Login
set session=serverbackup
rem Folder Settings.
set server_folder=/var/www/html/
set local_folder=c:\Server_Backup\Archives\
rem Path to winscp.
set winscp_path=c:\Progra~1\WinSCP3\WinSCP3.com
rem Execute script
%winscp_path% /script=script.tmp %filelog%
rem Delete temporary script
del script.tmp
thats the second part saved as a txt file.
set winscp_path="C:\Program Files\WinSCP\WinSCP.exe"
%winscp_path% /console /script=script.tmp
pause
and that part is saved as a .bat file
Please read documentation:
http://winscp.net/eng/docs/guide_automation#commands
http://winscp.net/eng/docs/scriptcommand_option
lewis@pepperit.com
Iv'e tried looking through them and tried codes with syncronise in it but i still can't get it to work, any help would be appreciated.
cheers
For "synchronize" the overwrite confirmations are disabled implicitly.
To generate log file, use /log=path_to_log_file command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
