Topic "WinSCP Drag and Drop to Windows 7 Windows Explorer"
Madu
When dragging and dropping files from WinSCP to the Windows Explorer folder, the files aren't get copied. Instead a scpXXXXX folder get created.
O/S: Windows 7
WinSCP: 5.13
Madu
Description: Attached is a screenshot of error window from WinSCP and the folder it creates.
Did you install WinSCP or are you using Portable executable?
Did you restart your machine since you have installed WinSCP?
