Topic "Time offset Bug"
Jessi'
Hi there,
WinSCP has a general problem whit the time offset as regular ftp.
If I don't use time offset, the file times has an exactly difference of 1 hour, because to different timezones from my PC and the server.
But, when I use the time offset use one hour additive, then I became only 59 Minutes Offset, the server file time are exactly 59 minutes different to my local file time.
Then, I try one minute more time offset an I get two minutes. The server file time exactly 61 Minutes different to my local file time.
Did you don't understand what I mean, look at the attached pictures, you can see what I mean in one picture...
Regards,
Jessi'
Description: the time offset bug at winscp programm 5.1.3 build 2881
Can you please attach a complete session log file showing directory listing using the default settings? Please use logging level Debug 1.
Jessi'
No problem! :)
jessikak@31.22.4.69.log (12.79 KB) [Download]
Description: (none)
Thanks. Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
vomsteinber-winscpbug(at)yahoo(dot)de
Jessi
I can see your eMail adress after I've logged in and didn't use the forum whit my login.
Regards,
JessiKath = Profilename
Jessi'
Sorry,
I can't see your email-adress, after I've logged in and I'm not able to use my account to answer in this forum.
Regards,
Jessi'
JessiKath
Now it's working, I don't know why... :)
http://winscp.net/tracker/show_bug.cgi?id=977
Possible root cause of this:
http://winscp.net/tracker/show_bug.cgi?id=978
