Topic "output from eventhandler"
I'm trying to modify example of event "FileTransfered" handler published as part of Session.SynchronizeDirectories Method powershell example. This handler use write-host cmdlet to display messages produced by the eventhandler. It works fine, but I need output from the handler futher in my main script so I need put this output to variable seen in main script. I tried to use "$script:variable" but it doesn't work: in eventhandler script block correct value is seen, but in main script it is empty. I can create temporary file from eventhandler, put there output message and finally read this file from main script but is isn't good solution.
Please help
Łukasz Duczmal
