Topic "Issue with error Cant Get Attributes of a file.."
saipaan
I am getting the error below::
Can't get attributes of file 'filename.xml'.
No such file or directory.
Error code: 2
Error message from server: /data/filename.xml is not a valid file path
Request code: 7
Here is the script:
REM Get today's date
for /f "tokens=2,3,4 delims=/ " %%a in ('date /t') do set filedate=%%c%%a%%b
for /f "tokens=2,3,4 delims=/ " %%a in ('date /t') do set filedate2=%%c-%%a-%%b
REM Set variables
Set LocalPath=D:\Location of folder
Set File2Get1=filename_%filedate2%.xml
REM =========== START SCRIPT ==========
REM ----------- PROCESS FILE2GET1 ----------
IF EXIST D:\location\%File2Get1% (
echo D:\location\%File2Get1% exists >> d:\location\Log.log
GOTO RECEIVED1
REM Set a few variables
set PARAM=d:\location\file.txt
echo option batch abort>>%PARAM%
echo option confirm off>>%PARAM%
echo open winscp>>%PARAM%
echo dir >>%PARAM%
echo Get %File2Get1%>>%PARAM%
echo close>>%PARAM%
echo exit>>%PARAM%
echo Start : %TODAY% >> d:\location\Log.log
time /t >> d:\location\Log.log
"C:\program files\winscp\winscp.com" /script=%PARAM% >>d:\location\Log.log
echo - >> d:\location\Log.log
echo D:\location\%File2Get1% retrieved >> d:\location\Log.log
:RECEIVED1
echo ----------------------------------- >> d:\location\Log.log
date /t >> d:\location\Log.log
echo *********************************************************** >> d:\location\Log.log
echo. >> d:\location\Log.log
echo END Transfert >> d:\location\Log.log
echo ____________________________________________________ >> d:\location\Log.log
. 2013-02-01 05:50:01.406 --------------------------------------------------------------------------
. 2013-02-01 05:50:01.406 WinSCP Version 5.1.2 (Build 2816) (OS 5.2.3790 Service Pack 2)
. 2013-02-01 05:50:01.406 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2013-02-01 05:50:01.406 Local account:
. 2013-02-01 05:50:01.406 Working directory:
. 2013-02-01 05:50:01.406 Command-line: "C:\program files\winscp\WinSCP.exe" /console=512 /consoleinstance=_5324_736 "/script=d:\Users\OCC\TEST\ftp_OCC_NBFTRD.txt"
. 2013-02-01 05:50:01.406 Time zone: Current: GMT-5, Standard: GMT-5, DST: GMT-4, DST Start: 3/10/2013, DST End: 11/3/2013
. 2013-02-01 05:50:01.406 Login time: Friday, February 01, 2013 5:50:01 AM
. 2013-02-01 05:50:01.406 Session name: OCC (Stored session)
. 2013-02-01 05:50:01.406 Host name:
. 2013-02-01 05:50:01.406 User name:
. 2013-02-01 05:50:01.406 Tunnel: No
. 2013-02-01 05:50:01.406 Transfer Protocol: SFTP (SCP)
. 2013-02-01 05:50:01.406 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2013-02-01 05:50:01.406 Proxy: none
. 2013-02-01 05:50:01.406 SSH protocol version: 2; Compression: No
. 2013-02-01 05:50:01.406 Bypass authentication: No
. 2013-02-01 05:50:01.406 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2013-02-01 05:50:01.406 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2013-02-01 05:50:01.406 SSH Bugs: A,A,A,A,A,A,A,A,A,A
. 2013-02-01 05:50:01.406 SFTP Bugs: A,A
. 2013-02-01 05:50:01.406 Return code variable: Autodetect; Lookup user groups: A
. 2013-02-01 05:50:01.406 Shell: default
. 2013-02-01 05:50:01.406 EOL: 0, UTF: 2
. 2013-02-01 05:50:01.406 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2013-02-01 05:50:01.406 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2013-02-01 05:50:01.406 Local directory:
. 2013-02-01 05:50:01.406 Cache directory changes: Yes, Permanent: Yes
. 2013-02-01 05:50:01.406 DST mode: 1
. 2013-02-01 05:50:01.421 Looking up host "198.133.169.198"
. 2013-02-01 05:50:01.421 Connecting to 198.133.169.198 port 10022
. 2013-02-01 05:50:01.531 Server version: SSH-2.0-Maverick_SSHD
. 2013-02-01 05:50:01.531 Using SSH protocol version 2
. 2013-02-01 05:50:01.531 We claim version: SSH-2.0-WinSCP_release_5.1.2
. 2013-02-01 05:50:01.593 Doing Diffie-Hellman group exchange
. 2013-02-01 05:50:01.828 Doing Diffie-Hellman key exchange with hash SHA-1
. 2013-02-01 05:50:01.984 Verifying host key rsa2
. 2013-02-01 05:50:01.984 Host key matches cached key
. 2013-02-01 05:50:01.984 Host key fingerprint is:
. 2013-02-01 05:50:01.984 ssh-rsa 1023 e9:8a:b6:dd:4d:ad:7b:32:bc:f2:aa:96:24:13:ef:de
. 2013-02-01 05:50:01.999 Initialised AES-256 CBC client->server encryption
. 2013-02-01 05:50:01.999 Initialised HMAC-SHA1 client->server MAC algorithm
. 2013-02-01 05:50:01.999 Initialised zlib (RFC1950) compression
. 2013-02-01 05:50:01.999 Initialised AES-256 CBC server->client encryption
. 2013-02-01 05:50:01.999 Initialised HMAC-SHA1 server->client MAC algorithm
. 2013-02-01 05:50:01.999 Initialised zlib (RFC1950) decompression
. 2013-02-01 05:50:02.218 Reading private key file "C:\Program Files\WinSCP\PuTTY\occftp_new\PrivateKey.ppk"
. 2013-02-01 05:50:02.218 Pageant is running. Requesting keys.
. 2013-02-01 05:50:02.234 Pageant has 1 SSH-2 keys
. 2013-02-01 05:50:02.234 Pageant key #0 matches configured key file
! 2013-02-01 05:50:02.234 Using username "cmo_355".
. 2013-02-01 05:50:02.281 Trying Pageant key #0
! 2013-02-01 05:50:02.374 Authenticating with public key "rsa-key-20130122" from agent
. 2013-02-01 05:50:02.468 Sending Pageant's response
. 2013-02-01 05:50:02.562 Access granted
. 2013-02-01 05:50:02.624 Opened channel for session
. 2013-02-01 05:50:02.984 Started a shell/command
. 2013-02-01 05:50:02.984 --------------------------------------------------------------------------
. 2013-02-01 05:50:02.984 Using SFTP protocol.
. 2013-02-01 05:50:02.984 Doing startup conversation with host.
> 2013-02-01 05:50:02.999 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2013-02-01 05:50:03.062 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2013-02-01 05:50:03.062 SFTP version 3 negotiated.
. 2013-02-01 05:50:03.062 We believe the server has signed timestamps bug
. 2013-02-01 05:50:03.062 We will use UTF-8 strings for status messages only
. 2013-02-01 05:50:03.062 Changing directory to "/data".
. 2013-02-01 05:50:03.062 Getting real path for '/data'
> 2013-02-01 05:50:03.062 Type: SSH_FXP_REALPATH, Size: 14, Number: 16
< 2013-02-01 05:50:03.140 Type: SSH_FXP_NAME, Size: 53, Number: 16
. 2013-02-01 05:50:03.140 Real path is '/data'
. 2013-02-01 05:50:03.140 Trying to open directory "/data".
> 2013-02-01 05:50:03.140 Type: SSH_FXP_LSTAT, Size: 14, Number: 263
< 2013-02-01 05:50:03.203 Type: SSH_FXP_ATTRS, Size: 29, Number: 263
. 2013-02-01 05:50:03.203 Getting current directory name.
. 2013-02-01 05:50:03.203 Startup conversation with host finished.
< 2013-02-01 05:50:03.203 Script: Active session: [1] OCC
> 2013-02-01 05:50:03.203 Script: dir
. 2013-02-01 05:50:03.203 Listing directory "/data".
> 2013-02-01 05:50:03.203 Type: SSH_FXP_OPENDIR, Size: 14, Number: 523
< 2013-02-01 05:50:03.265 Type: SSH_FXP_HANDLE, Size: 31, Number: 523
> 2013-02-01 05:50:03.265 Type: SSH_FXP_READDIR, Size: 31, Number: 780
< 2013-02-01 05:50:03.374 Type: SSH_FXP_NAME, Size: 5126, Number: 780
> 2013-02-01 05:50:03.374 Type: SSH_FXP_READDIR, Size: 31, Number: 1036
< 2013-02-01 05:50:03.437 Type: SSH_FXP_NAME, Size: 1579, Number: 1036
> 2013-02-01 05:50:03.437 Type: SSH_FXP_READDIR, Size: 31, Number: 1292
< 2013-02-01 05:50:03.484 Type: SSH_FXP_STATUS, Size: 40, Number: 1292
< 2013-02-01 05:50:03.484 Status code: 1
> 2013-02-01 05:50:03.499 Script: Get listfile.xml
. 2013-02-01 05:50:03.499 Listing file "listfile.xml".
> 2013-02-01 05:50:03.499 Type: SSH_FXP_LSTAT, Size: 42, Number: 1799
< 2013-02-01 05:50:03.546 Type: SSH_FXP_STATUS, Size: 40, Number: 1540
. 2013-02-01 05:50:03.546 Discarding reserved response
< 2013-02-01 05:50:03.609 Type: SSH_FXP_ATTRS, Size: 29, Number: 1799
. 2013-02-01 05:50:03.609 File: "/data/listfile.xml"
. 2013-02-01 05:50:03.609 Copying "/data/listfile.xml" to local directory started.
. 2013-02-01 05:50:03.609 Binary transfer mode selected.
. 2013-02-01 05:50:03.624 Checking existence of partially transfered file.
. 2013-02-01 05:50:03.624 Opening remote file.
> 2013-02-01 05:50:03.624 Type: SSH_FXP_OPEN, Size: 50, Number: 2051
< 2013-02-01 05:50:03.687 Type: SSH_FXP_HANDLE, Size: 27, Number: 2051
> 2013-02-01 05:50:03.687 Type: SSH_FXP_FSTAT, Size: 27, Number: 2312
< 2013-02-01 05:50:03.749 Type: SSH_FXP_ATTRS, Size: 29, Number: 2312
. 2013-02-01 05:50:03.749 Confirming overwriting of file.
> 2013-02-01 05:50:03.765 Type: SSH_FXP_READ, Size: 39, Number: 2565
< 2013-02-01 05:50:06.203 Status code: 1
. 2013-02-01 05:50:06.203 214 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2013-02-01 05:50:06.203 Type: SSH_FXP_CLOSE, Size: 27, Number: 30468
< 2013-02-01 05:50:06.234 Type: SSH_FXP_STATUS, Size: 32, Number: 29701
< 2013-02-01 05:50:06.265 Type: SSH_FXP_STATUS, Size: 32, Number: 29957
< 2013-02-01 05:50:06.265 Type: SSH_FXP_STATUS, Size: 32, Number: 30213
> 2013-02-01 05:50:06.281 Script: close
. 2013-02-01 05:50:06.281 Closing connection.
. 2013-02-01 05:50:06.281 Sending special code: 12
. 2013-02-01 05:50:06.281 Sent EOF message
There is no error in the log.
