Topic "can login via WinSCP client but not via DOS"
meliOnTheJob
howdy-
so if i launch Winscp.exe and enter the info, i can connect to the sftp with no problems.
when i navigate to the winscp folder via DOS and and test the connection by doing
winscp.com
open
sftp name
i get "searching for host....Network error: connection time out"
what am i missing here?
pls help. ultimately i have a script to login, connect, copy file...but if it doesn't work manually, it will not work in automation.
pls help
meliOnTheJob
also, i can ping it. and the firewall is off.
meliOnTheJob
anyone?
What is "open" ... "sftp name"?
You should do "open sftp://username@hostname".
Please see
http://winscp.net/eng/docs/scriptcommand_open
meliOnTheJob
"open...sftp" is another way of doing it interactively.
I tested with another sftp and was able to enter credentials.
I also tried what you suggested and got the same network error.
Just doesn't make sense that I can log in via client and not through DOS.
Make WinSCP log both in GUI and scripting and compare the logs. If that does not help, attach the logs here.
