Topic "Recursively Check sFTP folders"
rpeare
Hello, I'm in the process of writing a powershell script that recursively checks all folders on a sFTP site. In the process of doing this I write the folder names to a SQL log. This part is working fine except for one problem. I am not able to capture (I don't know how to capture) the error that occurs when I do not have access to a particular folder. The error message generated is:
Quote:
Exception calling "ListDirectory" with "1" argument(s): "Error listing directory '/Folder1/Folder2/Folder3/Folder4'."
At C:\Documents and Settings\rpeare.PPSDOM\Local Settings\Temp\df054dc2-58bc-4922-b02f-c9c3b04d22c0.ps1:90 char:44
+ $directory3 = $session.ListDirectory <<<< ("$FTP_RemoteBaseDir$Level1Dir/$Level2Dir")
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : DotNetMethodException
What I'd like to be able to do is capture this error and if it occurs mark an additional field in my SQL table indicating it's a restricted access folder.
Is there a way to capture the error WITHOUT terminating my script, I just want it to go on to trying the next folder.
Here is my current script:
cls
#**************************** START OPEN CONNECTION TO SQL DB **********************************
$ConnString = "Data Source=<Server Name>; Initial Catalog=<Database Name>; Integrated Security=SSPI"
$adOpenStatic = 3
$adLockOptimistic = 3
$objSecConn = New-Object -comobject ADODB.Connection      #connection to the SQL database
$objSecConn.Open("Provider=SQLOLEDB; $ConnString")
#**************************** END   OPEN CONNECTION TO SQL DB **********************************
# Load WinSCP .NET assembly
[Reflection.Assembly]::LoadFrom("c:\program files\winscp\WinSCP.dll") | Out-Null
#*********************  START Get Strings used in the remainder of the script *********************************
$RSStrings = New-Object -ComObject ADODB.Recordset
$RSStrings.Open("PS_Strings", $objSecConn, $adOpenStatic, $adLockOptimistic)
$FTP_Server = $RSStrings.Fields.Item("FTP_Address").value
$FTP_User = $RSStrings.Fields.Item("FTP_User").value
$FTP_Pass = $RSStrings.Fields.Item("FTP_Password").value
$FTP_FingerPrint = $RSStrings.Fields.Item("FTP_FingerPrint").value
$FTP_BaseDir = $RSStrings.Fields.Item("Server_Base_Path").value
$FTP_RootDir = $RSStrings.Fields.Item("FTP_LocalRootFolder").value
$FTP_RootDir = "$FTP_BaseDir$FTP_RootDir"
$FTP_RemoteBaseDir = $RSStrings.Fields.Item("FTP_RemoteRootFolder").value
$FM_ConnStr = $RSStrings.Fields.Item("File_Maintenance_Connection_String").value
#*********************  END   Get Strings used in the remainder of the script *********************************
# Setup session options
$sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
$sessionOptions.HostName = $FTP_Server
$sessionOptions.UserName = $FTP_User
$sessionOptions.Password = $FTP_Pass
$sessionOptions.SshHostKeyFingerprint = $FTP_FingerPrint
$directory = $session.ListDirectory($FTP_RemoteBaseDir)
foreach ($fileInfo in $directory.Files)
   if ($fileInfo.IsDirectory -eq $true)
      $Level1Dir = $fileInfo.name
      if ($Level1Dir -ne "." -and $Level1Dir -ne "..")
         $query = "SELECT * FROM PS_FTPFolders WHERE ((Directory1) = '$level1Dir' AND (Directory2) Is Null)"
         $objFC = New-Object -comobject ADODB.Recordset
         $objFC.Open($query, $objSecConn, $adOpenStatic, $adLockOptimistic)
         if ($objfc.absoluteposition -eq "adposunknown")
            $objAddConn = New-Object System.Data.SqlClient.SqlConnection($ConnString)
            $objAddConn.Open()
            $cmd = $objAddConn.CreateCommand()
            $cmd.CommandText ="INSERT PS_FTPFolders (Directory1) VALUES ('$Level1Dir')"
            $cmd.ExecuteNonQuery()
            $objAddConn.Close()
         $objFC.Close()
         $directory2 = $session.ListDirectory("$FTP_RemoteBaseDir$Level1Dir")
         foreach ($fileInfo in $directory2.Files)
               $Level2Dir = $fileInfo.name
               if ($Level2Dir -ne "." -and $Level2Dir -ne "..")
                  $query = "SELECT * FROM PS_FTPFolders WHERE ((Directory1) = '$level1Dir' AND (Directory2) = '$level2dir' and (Directory3) Is Null)"
                     $objAddConn.Open()
                     $cmd.CommandText ="INSERT PS_FTPFolders (Directory1, Directory2) VALUES ('$Level1Dir', '$Level2Dir')"
                     $objAddConn.Close()
                  $objFC.Close()
                  $directory3 = $session.ListDirectory("$FTP_RemoteBaseDir$Level1Dir/$Level2Dir")
                  foreach ($fileInfo in $directory3.Files)
                        $Level3Dir = $fileInfo.name
                        if ($Level3Dir -ne "." -and $Level3Dir -ne "..")
                           $query = "SELECT * FROM PS_FTPFolders WHERE ((Directory1) = '$level1Dir' AND (Directory2) = '$level2dir' and (Directory3) = '$Level3Dir' and (Directory4) Is Null)"
                              $objAddConn.Open()
                              $cmd.CommandText ="INSERT PS_FTPFolders (Directory1, Directory2, Directory3) VALUES ('$Level1Dir', '$Level2Dir', '$Level3Dir')"
                              $objAddConn.Close()
                           $objFC.Close()
$objSecConn.close()
Any help would be appreciated, thanks.
rp
So, is the problem that you do not know how to catch exceptions in PowerShell?
For that see any WinSCP .NET example for PowerShell.
E.g. http://winscp.net/eng/docs/library#powershell
