Topic "Timestamp differences due to timezone and DST"
disign
Hello, thanks for the wonderful software and all the efforts You put in supporting it.
I am getting different timestamps when synchronizing with ftp.
Win 7 x64
WinSCP 5.1.3 2881
GMT+2 with DST, FTP connection no timeshift
I'm synchronizing remote directory \local target, mirror, based on timestamp\, local folder is empty. After synchronization in local folder i have file with stamp 2 hours earlier than the remote. On second synchronization the file is downloaded again due to 2 hour timestamp difference. On manual copy the overwrite confirmation dialog states 1 hour difference. Log file - gmt_plus_2_dst.log
If I change local machine to GMT with DST, synchronization works as expected and timestamps are equal. On file overwrite confirmation again there is one hour difference, but after copy timestamps are equal. Log - gmt_dst.log
If local machine is GMT no DST everything is working as expected. Log - gmt.log
Tested with another FTP server same results. Tried using timeshift option, not giving expected results because it is designed to correct server errors not local issues.
Thanks in advance.
gmt.log (13.68 KB) [Download]
Description: GMT
gmt_dst.log (12.66 KB) [Download]
Description: GMT DST
gmt_plus_2_dst.log (20.18 KB) [Download]
Description: GMT+2 DST
disign
Mail address sent.
disign
I can confirm the bug is fixed in 5.1.4
Thanks for your feedback.
