Topic "ASP.NET Error parsing session log file"
mythos8
There were only 4 views and 3 of them are mine when I posted this in the .NET section so I'm re-posting it here.
I copied the example code straight from the .NET & Com Library examples and obviously edited the host, credentials and key. I'm getting an "Error parsing session log file" when I try to open a session in my C# ASP.NET project. I only have some basic transfers to peform so I don't really need logging. But I cannot seem to turn logging off. If nothing else I would need to get logging working but can it be turned off? A new session defautls to NULL values for the log paths but this genearates an error. Setting them to "" doesn't work either.
Also the example code does not mention if it works in ASP.NET but I assume that it should?
Thanks.
Please set Session.DebugLogPath and attach the log.
mythos8
Thanks for your reply but I ended up reverting the changes I made and went with another solution. If I still had the code I would do as you suggested for your information but I don't have that code anymore.
J
I have the same problem while sending big (>2GB) zip files in the loop. After finishing sending the first file I get error:
Part of log file below:
[2013-03-08 11:30:23.692Z] [0008] Skipping 76 nodes
[2013-03-08 11:30:23.692Z] [0008] Read node 77: Element group
[2013-03-08 11:30:23.692Z] [0008] Log contents has not changed
[2013-03-08 11:30:23.692Z] [0008] SessionLogReader.Read leaving
[2013-03-08 11:30:23.692Z] [0008] SessionLogReader.Read entering
[2013-03-08 11:30:23.692Z] [0008] Read node 78: Whitespace
[2013-03-08 11:30:23.693Z] [0008] Log contents has not changed
[2013-03-08 11:30:23.693Z] [0008] SessionLogReader.Read leaving
[2013-03-08 11:30:23.693Z] [0008] SessionLogReader.Read entering
[2013-03-08 11:30:23.699Z] [0008] Closing log
[2013-03-08 11:30:23.699Z] [0008] Log contents has not changed
[2013-03-08 11:30:23.705Z] [0008] Exception: WinSCP.SessionLocalException: Error parsing session log file ---> System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: group, session. Line 40, position 1.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at WinSCP.SessionLogReader.DoRead()
--- End of inner exception stack trace ---
[2013-03-08 11:30:23.712Z] [0008] SessionLogReader.Read leaving
[2013-03-08 11:30:23.712Z] [0008] ElementLogReader.Dispose entering
[2013-03-08 11:30:23.712Z] [0008] ElementLogReader.ReadToEnd entering
[2013-03-08 11:30:23.712Z] [0008] SessionLogReader.Read entering
[2013-03-08 11:30:23.712Z] [0008] Opening log
[2013-03-08 11:30:23.718Z] [0008] SessionLogReader.Read leaving
[2013-03-08 11:30:23.718Z] [0008] ElementLogReader.ReadToEnd leaving
[2013-03-08 11:30:23.718Z] [0008] Swallowing exception
[2013-03-08 11:30:23.718Z] [0008] ElementLogReader.Dispose leaving
[2013-03-08 11:30:23.718Z] [0008] CallstackAndLock..ctor leaving
Please email me a both complete session log file and debug log file.
Mesquida86
Please help me, I have an exception of WinSCP.SessionLocalException and I don't know how can I solve it! this is the exception: Element "group" not found in the log file. WinSCP.SessionLocalException: Element "group" not found in the log file at WinSCP.Session.GetFiles(String remotePath, String localPath, Boolean remove, TransferOptions options)
Could you please help me?
Thanks!
Thanks!
Please start a new thread and attach both session log file (Session.SessionLogPath) and debug log file (Session.DebugLogPath).
