Topic "How i can connect to a session"
I want to create a new session from a dotnet (c#) program.
Not intended to use existing saved session,want to prompt user to provide the desired credentials.
Any pointers would be very helpful.
Thanks & Regards
Alankar Singh
First, WinSCP .NET assembly is probably not a good fit for use from GUI applications.
Please read
Anyway, you need to implement the prompts yourselt and then feed the data to SessionOptions class. There's no support for prompts in the library itself.
