Topic "Progress indicator within a script?"
Fox
When I run the winscp.com and do open mysession and then get file.ext I get a nice indicator for the download process, but when I do the same within a script it just stands there blinking until it's done and then it prints all that happened.
Is there a way to get it to show a more "live" progress within a script?
My script is in JS if that matters.
WinSCP does not print progress to redirected output.
With upcoming 5.2 you can use WinSCP .NET assembly from your JS and handle Session.FileTransferProgress event.
Fox
Ok thanks! I'll try that once it's out then.
Right now I went around the problem by creating a batch file that start WinSCP.exe with all the parameters I need and run that from within the script instead of directly running the command. Not as pretty but it works. Smile
aerze
The Session.FileTransferProgress Event won't fire.
var zvSession = WScript.CreateObject('WinSCP.Session','sessionEvent_');
// This event won't fire
function sessionEvent_FileTransferProgress(sender, args) {
    WScript.echo('start');
// Although this one does
function sessionEvent_FileTransferred(sender, args) {
    WScript.echo(args.FileName);
    WScript.echo('end');
Am I implementing this wrong? I'm having a hard time finding any JScript examples.
BTW If you don't mind, I could JScript examples for the site.
This tool has been super useful so far.
jbratten
I too find that FileTransferred fires after each file, but FileTransferProgress does not fire at all.
WinSCP Ver. 5.5.1 Build 3970
WinSCPNet Ver. 5.5.1 (at least that's what the zip file is named)
Windows XP and 7
VBA in Access 2003/2007 and Excel 2007
The file transfer occurs and completes without any errors or problems. Just no progress updates.
'// Instantiate Class
Sub testEDI()
    Dim objEDI As New OfficeEDI
    objEDI.doXfer
End Sub
'// Class OfficeEDI
Option Compare Database
Private WithEvents objSession As WinSCPnet.Session
Public Sub doXfer()
    Dim objOptions As New WinSCPnet.SessionOptions
    Set objSession = New WinSCPnet.Session
    objOptions.Protocol = Protocol_Sftp
    objOptions.Portnumber = 30
    objOptions.hostname = "@xxx.xxx.xxx.xxx"
    objOptions.UserName = "test"
    objOptions.Password = "xxxxxxxx"
    objOptions.SshHostKeyFingerprint = "ssh-dss 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
    objSession.Open objOptions
    If objSession.opened Then
        Debug.Print "Session Opened"
   objSession.putfiles "F:\FileName*", "//Test//*", False
    End If
    objSession.dispose
    Set objOptions = Nothing
    Set objSession = Nothing
End Sub
Private Sub objSession_FileTransferProgress(ByVal sender As Object, ByVal e As FileTransferProgressEventArgs)
    Debug.Print Format(e.overallprogress, "Percent")
End Sub
Private Sub objSession_FileTransferred(ByVal sender, ByVal e As TransferEventArgs)
    Debug.Print e.FileName & " To " & e.destination
End Sub
BoringPortlander
I am trying to figure this out as well. I want to add a simple dialog bog with a progress bar while I run a Syncronization with the newest WinSCPNet.dll libs
Any help would be appreciated
Thanks for your reports.
http://winscp.net/tracker/show_bug.cgi?id=1134
I'll send dev version with fix for testing to registered reporters.
jbratten
The development version fixed the issue for me in VBA (Access, etc).
Thank you for the prompt response and fix.
Thanks for your feedback.
xscraper
I just got the WinSCP .Net library from Nuget and I used it in my code. I also do not see FileTransferProgress event in the Session class. How do I get the latest build where the bug is fixed? Thanks a lot.
What NuGet package? Anyway, no NuGet package is maintained by WinSCP team. They are all outdated. You should download the .NET assembly from this site.
But, WinSCP 5.5.2 will be released today and as part of that we are taking over "WinSCP" NuGet package and will be keeping it up to date.
http://www.nuget.org/packages/WinSCP/
http://winscp.net/tracker/show_bug.cgi?id=1145
