Topic "request for Bug #169"
AndreasDorner
i use winscp nearly the whole day or at least a few times a day... - and i like it very much! Thanks for that!
And also i need to compare files between remote and local file system. There i use the software "compare it" (grigsoft).
Unfortunately there is the bug #169 (or a new feature?), where its not possible to save back the remote file...
Is there a possibility to raise the priority again (high => higher)?
I only want to describe my needs to the software... - and of course i would support by a donation!
thanks in advance and
greetings,
Andreas
(i use the latest version of winscp on win7-x64)
Registered your interest Smile
http://winscp.net/tracker/show_bug.cgi?id=169
AndreasDorner
5.6.2 (not released yet)
Uploading back files modified by local custom command. 169
Thank you!!! Great... -> donated as promised! Wink
Andreas Dorner
apps4print
Thanks again for your donation.
Did you test the custom commands improvement?
I appreciate any feedback.
Janet
Very nice, just installed on my GS2 it looks great , very smtooh, pretty yet functional. Its in Beta but works better than some apps that left Beta long ago.
