Topic "No delete entry in XML log - bug?"
Hey there,
I'm using WinSCP 5.1.4 on Windows Server 2003 SBS to synchronize my website to my server in order to have a backup.
As it might be that multiple people work on the webspace I'd like to preserve a log of what has changed.
I'm using WinSCP with scripting, the script is as follows:
synchronize -delete -criteria=either -transfer=binary local "C:\" "/websites/"
and I'll call it by use of a batch (.bat) file:
winscp.exe /log=mirror.log /xmllog=mirror.xml /script=mirror-website.script.txt
Everything works as expected (files are synchronized), but in the mirror.xml no delete command is recorded.
So I renamed a file on the server, this is the essential log from mirror.log (I renamed "TEST.rename" to "TEST.2Ren")
. 2013-02-26 15:36:18.774 Remote file '/websites/' [2013-02-26T14:19:43.000Z] [28] is new
< 2013-02-26 15:36:52.431 Script: 'C:\\TEST.rename' deleted
but the XML log only shows:
<session xmlns="" name="" start="2013-02-26T14:36:13.883Z">
    <filename value="/websites/" />
    <destination value="C:\\TEST.2Ren" />
    <result success="true" />
but I would expect that there will also be a `rm` tag in the XML log, stating that the file `TEST.rename` was deleted.
In the documentation ( it states that the rm tag is associated to `synchronize local|both -delete`.
Am I doing something wrong or is this a bug?
Thank you very much for your support.
The XML log records operations on remote files only.
What applies to <rm> tag too:
Deleting of one (or more) remote file or directory.
