Topic "interpretation of the log"
kingkurt
hello, is there an interpretion where i can easily analyze my log?
for example:
2013-02-28 07:53:33.837 File: "468_Zim125_2013_02_28_07_49_09_550.pdf"
. 2013-02-28 07:53:34.103 Copying "468_Zim125_2013_02_28_07_49_09_550.pdf" to remote directory started.
. 2013-02-28 07:53:34.103 Binary transfer mode selected.
. 2013-02-28 07:53:34.103 Checking existence of file.
> 2013-02-28 07:53:34.103 Type: SSH_FXP_LSTAT, Size: 48, Number: 263
< 2013-02-28 07:53:34.118 Type: SSH_FXP_STATUS, Size: 32, Number: 263
< 2013-02-28 07:53:34.118 Status code: 2
. 2013-02-28 07:53:34.118 Checking existence of partially transfered file.
> 2013-02-28 07:53:34.118 Type: SSH_FXP_LSTAT, Size: 57, Number: 519
< 2013-02-28 07:53:34.118 Type: SSH_FXP_STATUS, Size: 32, Number: 519
. 2013-02-28 07:53:34.118 Opening remote file.
> 2013-02-28 07:53:34.118 Type: SSH_FXP_OPEN, Size: 73, Number: 771
< 2013-02-28 07:53:34.134 Type: SSH_FXP_HANDLE, Size: 17, Number: 771
> 2013-02-28 07:53:34.134 Type: SSH_FXP_WRITE, Size: 4125, Number: 1286
. 2013-02-28 07:53:35.525 226 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2013-02-28 07:53:35.525 Type: SSH_FXP_CLOSE, Size: 17, Number: 30468
< 2013-02-28 07:53:35.525 Type: SSH_FXP_STATUS, Size: 17, Number: 30214
< 2013-02-28 07:53:35.525 Status code: 0
< 2013-02-28 07:53:35.697 Type: SSH_FXP_STATUS, Size: 17, Number: 30468
< 2013-02-28 07:53:35.697 Status code: 0
> 2013-02-28 07:53:35.697 Type: SSH_FXP_RENAME, Size: 100, Number: 30738
< 2013-02-28 07:53:35.697 Type: SSH_FXP_STATUS, Size: 17, Number: 30738
> 2013-02-28 07:53:35.697 Type: SSH_FXP_SETSTAT, Size: 60, Number: 1033
< 2013-02-28 07:53:35.697 Type: SSH_FXP_STATUS, Size: 17, Number: 1033
> 2013-02-28 07:53:35.697 Script: close
. 2013-02-28 07:53:35.697 Closing connection.
what are the different "SSH_xxxxx" , SIZE and NUMBER syntax meant?
how can i check which filesize this file had, (and finally how many bytes transfered to the endpoint)?
how can i be sure that the filetransfer completed successfully?
thx kurt
As long as there are no errors in the log and the exit code of WinSCP is 0, the file transfer completed successfully. At least from WinSCP point of view.
See http://winscp.net/eng/docs/faq_script_result
kingkurt66
thank you Very Happy
