Topic "Status Code -"
Snap
Hello javascript:emoticon('Very Happy') , i need help to understand the codes list in log file written under, the codes are written in red.
Thanks to all
. 2013-03-03 02.00.01.151 --------------------------------------------------------------------------
. 2013-03-03 02.00.01.151 WinSCP Versione 4.3.9 (Build 1817) (OS 5.2.3790 Service Pack 2)
. 2013-03-03 02.00.01.151 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2013-03-03 02.00.01.151 Local account: **********************
. 2013-03-03 02.00.01.151 Login time: domenica 3 marzo 2013 2.00.01
. 2013-03-03 02.00.01.151 Session name: ******************** (Stored session)
. 2013-03-03 02.00.01.151 Host name: ********** (Port: 22)
. 2013-03-03 02.00.01.151 User name: root (Password: Yes, Key file: No)
. 2013-03-03 02.00.01.151 Tunnel: No
. 2013-03-03 02.00.01.151 Transfer Protocol: SFTP (SCP)
. 2013-03-03 02.00.01.151 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2013-03-03 02.00.01.151 Proxy: none
. 2013-03-03 02.00.01.151 SSH protocol version: 2; Compression: No
. 2013-03-03 02.00.01.151 Bypass authentication: No
. 2013-03-03 02.00.01.151 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2013-03-03 02.00.01.151 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2013-03-03 02.00.01.151 SSH Bugs: A,A,A,A,A,A,A,A,A
. 2013-03-03 02.00.01.151 SFTP Bugs: A,A
. 2013-03-03 02.00.01.151 Return code variable: Autodetect; Lookup user groups: Yes
. 2013-03-03 02.00.01.151 Shell: default
. 2013-03-03 02.00.01.151 EOL: 0, UTF: 2
. 2013-03-03 02.00.01.151 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2013-03-03 02.00.01.151 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2013-03-03 02.00.01.151 Local directory: ********, Remote directory: home, Update: No, Cache: Yes
. 2013-03-03 02.00.01.151 Cache directory changes: Yes, Permanent: Yes
. 2013-03-03 02.00.01.151 DST mode: 1
. 2013-03-03 02.00.01.151 Looking up host "**********"
. 2013-03-03 02.00.01.151 Connecting to ********** port 22
. 2013-03-03 02.00.01.370 Server version: SSH-1.99-OpenSSH_3.9p1
. 2013-03-03 02.00.01.370 Using SSH protocol version 2
. 2013-03-03 02.00.01.370 We claim version: SSH-2.0-WinSCP_release_4.3.9
. 2013-03-03 02.00.01.386 Doing Diffie-Hellman group exchange
. 2013-03-03 02.00.01.417 Doing Diffie-Hellman key exchange with hash SHA-1
. 2013-03-03 02.00.01.698 Host key fingerprint is:
. 2013-03-03 02.00.01.698 ssh-rsa 1024 d2:87:b7:aa:b2:07:3f:3d:2e:1a:6c:81:8b:bf:70:ed
. 2013-03-03 02.00.01.698 Initialised AES-256 SDCTR client->server encryption
. 2013-03-03 02.00.01.698 Initialised HMAC-SHA1 client->server MAC algorithm
. 2013-03-03 02.00.01.698 Initialised AES-256 SDCTR server->client encryption
. 2013-03-03 02.00.01.698 Initialised HMAC-SHA1 server->client MAC algorithm
! 2013-03-03 02.00.01.745 Using username "root".
. 2013-03-03 02.00.01.745 Prompt (7, SSH password, , &Password: )
. 2013-03-03 02.00.01.745 Using stored password.
. 2013-03-03 02.00.01.745 Sent password
. 2013-03-03 02.00.01.776 Access granted
. 2013-03-03 02.00.01.776 Opened channel for session
. 2013-03-03 02.00.01.823 Started a shell/command
. 2013-03-03 02.00.01.823 --------------------------------------------------------------------------
. 2013-03-03 02.00.01.839 Using SFTP protocol.
. 2013-03-03 02.00.01.839 Doing startup conversation with host.
> 2013-03-03 02.00.01.839 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2013-03-03 02.00.01.901 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2013-03-03 02.00.01.901 SFTP version 3 negotiated.
. 2013-03-03 02.00.01.901 We believe the server has signed timestamps bug
. 2013-03-03 02.00.01.901 We will use UTF-8 strings for status messages only
. 2013-03-03 02.00.01.901 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2013-03-03 02.00.01.901 Getting current directory name.
. 2013-03-03 02.00.01.901 Getting real path for '.'
> 2013-03-03 02.00.01.901 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2013-03-03 02.00.01.901 Type: SSH_FXP_NAME, Size: 31, Number: 16
. 2013-03-03 02.00.01.901 Real path is '/root'
. 2013-03-03 02.00.01.901 Startup conversation with host finished.
< 2013-03-03 02.00.01.901 Script: Sessione attiva: [1] ************
> 2013-03-03 02.00.01.901 Script: cd /dir1/dir2
. 2013-03-03 02.00.01.901 Cached directory change via "/dir1/dir2" to "/dir1/dir2".
< 2013-03-03 02.00.01.901 Script: /dir1/dir2
> 2013-03-03 02.00.01.901 Script: get file.DMP -resume -preservetime
. 2013-03-03 02.00.01.901 Listing file "file.DMP".
> 2013-03-03 02.00.01.901 Type: SSH_FXP_LSTAT, Size: 45, Number: 263
< 2013-03-03 02.00.01.901 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2013-03-03 02.00.01.901 File: "/dir1/dir2/file.DMP"
. 2013-03-03 02.00.01.901 Copying "/dir1/dir2/file.DMP" to local directory started.
. 2013-03-03 02.00.01.901 Binary transfer mode selected.
. 2013-03-03 02.00.01.901 Checking existence of partially transfered file.
. 2013-03-03 02.00.01.901 Opening remote file.
> 2013-03-03 02.00.01.901 Type: SSH_FXP_OPEN, Size: 53, Number: 515
< 2013-03-03 02.00.01.901 Type: SSH_FXP_HANDLE, Size: 13, Number: 515
> 2013-03-03 02.00.01.901 Type: SSH_FXP_FSTAT, Size: 13, Number: 776
> 2013-03-03 02.00.01.901 Type: SSH_FXP_READ, Size: 25, Number: 1029
. 2013-03-03 02.00.01.901 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2013-03-03 02.00.01.901 Type: SSH_FXP_ATTRS, Size: 37, Number: 776
. 2013-03-03 02.00.01.901 Storing reserved response
< 2013-03-03 02.02.50.479 Status code: 1
. 2013-03-03 02.02.50.479 53271 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2013-03-03 02.02.50.479 Type: SSH_FXP_CLOSE, Size: 13, Number: 6820612
< 2013-03-03 02.02.50.479 Type: SSH_FXP_STATUS, Size: 28, Number: 6819845
< 2013-03-03 02.02.50.479 Type: SSH_FXP_STATUS, Size: 28, Number: 6820101
< 2013-03-03 02.02.50.479 Type: SSH_FXP_STATUS, Size: 28, Number: 6820357
> 2013-03-03 02.02.50.823 Script: cd /dir1/dir3
. 2013-03-03 02.02.50.823 Cached directory change via "/dir1/dir3" to "/dir1/dir3".
. 2013-03-03 02.02.50.823 Getting current directory name.
< 2013-03-03 02.02.50.823 Script: /dir1/dir3
> 2013-03-03 02.02.50.823 Script: getfile.LOG -resume -preservetime
. 2013-03-03 02.02.50.823 Listing file "Export_BMSPROD.LOG".
> 2013-03-03 02.02.50.823 Type: SSH_FXP_LSTAT, Size: 43, Number: 6820871
< 2013-03-03 02.02.50.823 Type: SSH_FXP_STATUS, Size: 24, Number: 6820612
. 2013-03-03 02.02.50.823 Discarding reserved response
< 2013-03-03 02.02.50.823 Type: SSH_FXP_ATTRS, Size: 37, Number: 6820871
. 2013-03-03 02.02.50.823 File: "/dir1/dir3/Export_BMSPROD.LOG"
. 2013-03-03 02.02.50.823 Copying "/dir1/dir3/Export_BMSPROD.LOG" to local directory started.
. 2013-03-03 02.02.50.823 Binary transfer mode selected.
. 2013-03-03 02.02.50.823 Checking existence of partially transfered file.
. 2013-03-03 02.02.50.823 Opening remote file.
> 2013-03-03 02.02.50.823 Type: SSH_FXP_OPEN, Size: 51, Number: 6821123
< 2013-03-03 02.02.50.823 Type: SSH_FXP_HANDLE, Size: 13, Number: 6821123
> 2013-03-03 02.02.50.823 Type: SSH_FXP_FSTAT, Size: 13, Number: 6821384
> 2013-03-03 02.02.50.823 Type: SSH_FXP_READ, Size: 25, Number: 6821637
. 2013-03-03 02.02.50.823 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2013-03-03 02.02.50.823 Type: SSH_FXP_ATTRS, Size: 37, Number: 6821384
. 2013-03-03 02.02.50.823 Storing reserved response
< 2013-03-03 02.02.50.854 Status code: 1
. 2013-03-03 02.02.50.854 69 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2013-03-03 02.02.50.854 Type: SSH_FXP_CLOSE, Size: 13, Number: 6831364
< 2013-03-03 02.02.50.854 Type: SSH_FXP_STATUS, Size: 28, Number: 6830597
< 2013-03-03 02.02.50.854 Type: SSH_FXP_STATUS, Size: 28, Number: 6830853
< 2013-03-03 02.02.50.854 Type: SSH_FXP_STATUS, Size: 28, Number: 6831109
> 2013-03-03 02.02.50.854 Script: exit
. 2013-03-03 02.02.50.854 Script: Exit code: 0
. 2013-03-03 02.02.50.854 Closing connection.
. 2013-03-03 02.02.50.854 Sending special code: 12
. 2013-03-03 02.02.50.854 Sent EOF message
Very Happy
Status code: 1 = EOF (SFTP protocol)
Sending special code: 12 = EOF (Terminal code)
See also http://winscp.net/eng/docs/sftp_codes
snap
Thank you very much prikryl for your help
For details on "Sending special code: 12", see
http://winscp.net/eng/docs/message_special_code
