Topic ""Rename" is missing at the right-click-menu in local window"
raka007
when I'm doing some action in the remote window and want to rename then a file/directory in the local window, "Rename" is missing at the right-click-menu! It's only shown again, if I left-click in the local window or a file/directory first (or two times with right mouse button there).
I'm using WinSCP 5.1.4 on Windows 7.
Thanks.
Ralf
raka007
Does noone have an idea? Is it a bug?
Thanks for your report. Will check.
Though note that in upcoming 5.2, the system context menu will be replaced with built-in menu that does not suffer the problem.
raka007
Sounds good! Thank you very much for the information, Mr. Přikryl.
