Topic "Problem with Excluding directories"
ldsang
Hello all. I've been trying to get WinSCP to exclude some directories from sync but have had some odd issues. Here's my basic script (run from a batch file):
option batch on
option transfer binary
option exclude "M:\mypath\localvars\*"
option exclude "M:\mypath\src\*"
option exclude "M:\mypath\obj\*"
open server:pass@99.99.99.99
synchronize remote M:\local\path /remote/path
The basic sync works, but it also completely syncs the "src" dir. Odd thing is it doesn't sync the "obj" dir. Also, it syncs 1 file in the "localvars" dir, but doesn't sync the rest of the files in that dir. I noticed this because I just put an additional file into that dir that I need different on my local server and the remote. There are other files that need to be different as well, but only 1 file in that dir is synced with my local server. Any ideas on why that script I posted would exhibit the behavior I've described?[/code]
1) "option exclude exclude_mask" is deprecated command, use "synchronize -filemask=|exclude_mask" instead.
2) Every "option exclude" command overwrites previous value. You need to set all masks at once by separating whem with semicolon. But of course, use the -filemask.
See example:
http://winscp.net/eng/docs/scriptcommand_synchronize#examples
And documentation:
http://winscp.net/eng/docs/file_mask
And of course, make sure you are using the latest version of WinSCP.
ldsang
Semicolons, that was my problem. One of the perils of using search is getting info on depreciated commands. Thanks!
guestuser
I am trying to exclude the current directory with: -filepath=|.\*
However, it is not excluding it... Confused
guestuser
i just updated to newest version, works great now!
McSnoogins
I'm still a bit mixed up with the new file masks, can someone translate this for me please?
I used to use
option exclude c:\data\software
I've tried replacing it with
synchronize -filemask="|c:\data\software" remote -criteria=Both C:\Data\Software /Data/Software
But it seems to synchronize the data folder regardless. Can you show me what i should be using please?
mcsnoogins
I used to use
Last line should be "But it seems to synchronize the Software folder regardless"
Mcsnoogins
mcsnoogins wrote:
I used to use
Bit of trial and error resulted in the following answer:
synchronize remote -criteria=Both -filemask="| Software/" C:\Data\ /Data/
Now synchronizing all files and folders but excluding the folder c:\data\Software
